let’s asume usual situation with ap and wireless client stations.
sometimes, when user starts to upload using bit comet or download master, all signals goes up, ping times grows fataly.
limiting connection speed by access-list entries properties doesen’t help
When you say signal grows, do you mean it becomes weaker or stronger? Be a bit more specific on your power source and what wireless cards you are using.
also note what power supply you are using and whether its going via POE and the distance. It could have to do with voltage drop to the routerboard. I can’t think of any other reason. Have you tried upgrading to the latest ROS?
You need to disable speeds above 24 megs. Your wireless client and AP will transmit at a lower power rate above 24 megs and cause the problem you are seeing.
