I´m trying to configure a simple vlan with single interface, but find some issues:
[admin@MikroTik] > export
# 2023-11-30 15:46:30 by RouterOS 7.12.1
# software id =
set [ find default-name=ether1 ] disable-running-check=no
set [ find default-name=ether2 ] disable-running-check=no
/interface vlan
add interface=ether1 name=wan vlan-id=101
add name=wan1
/port
set 0 name=serial0
set 1 name=serial1
add address=10.10.10.84/24 disabled=yes interface=wan network=10.10.10.0
add address=10.10.10.84/24 interface=ether1 network=10.10.10.0
/ip dhcp-client
add disabled=yes interface=ether1
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=10.10.10.1 pref-src="" routing-table=main suppress-hw-offload=no
/system note
set show-at-login=no
With address configured on interface ehter1, gateway is reacheable but traffic has no 802.1q (as logic).
If i disable address on ether1 and enable on vlan “wan”, gateway is no recheable.
I´m loosing any configuration?
Thanks!
