Simple VPN - MTU size?
Hi guys,
I use some hAP Lites for my SOHOS, everything works ok, I set up a VPN with one IP wich allows me to get into the local LAN remotely and do/check stuff like NAS and printers.
I’m experiencing random “slowness” sometimes (packets loss?), like for example, 5 minutes I can browse the LAN shares perfectly and then everything slows down. In the tutorial I used for setting up a simple VPN I read about changing the MTU size because of overhead. Should I try it? I will post the cfg.
My scheme looks like this
hAP lite with pppoe wan and internal dhcp serving 192.168.1.1/24 from. 100 to. 200
VPN set up so remote client Ip is .99, so I get access to the LAN internal shares, Web services etc.
