Simple Walled Garden Setup
I want to setup up a simple (all things being equal) walled garden. From the user manual I have two choices an IP Walled Garden or an HTTP Walled Garden. Without making it complicated. Users should be allowed to connect to the AP and only have access to the pages I select. The application is a real estate situation. Potential buyers can connect to the AP, be directed to the realtors homepage or spec sheet for the property. Fairly straight forward. Please forgive my simple question but my experience with this router is basic and I could use some help.
Eventually, this application may lead to going to a Radius Server for AAA but that’s down the road still.
I have the Ethernet and Wireless Ports assigned to Bridge1. It works as an AP with and without security settings.
Many thanks in advance.
RouterOS 3.24
< BUMP >
Is my question too hard or too simple? Anyone?
start by hitting the “Setup” button in the Winbox Hotspot menu, and fill out what is asked. When hotspot login works, you can add your real estate page to the walled garden list in the hotspot menu. This will make it the only page that’s accessible without logging in.
You can then modify the hotspot login page to include a link to this page, or even make it redirect after a few seconds, or whatever you want. once you will try to do it, it will be easier to help you, as you will have more specific questions
I can’t see a question there.
Many thanks.
