I have a RB433AH routerboard with routeros 4.11.
I try to connect to a wireless AP. (After I have this running I want to share it through NAT).
For the wlan1 interface I have set mode to station and the band to 2.4Ghz-B/G.
After a scan I connect to the desired network.
In the ‘registration’ tab it shows that the link is up. (and in the interface is says ‘connected to ess’ in the bottom).
I’ve made a DHCP client for wlan1. It cannot get a lease.
What bothers me is that I cannot see which security settings are needed for this AP. There is no question / notice or result.
I tried to make security profile:
After connecting with a windows PC, it says
security type: no authentication (open)
encryption type: WEP
key index: 1
Mode: “static keys required”
For static keys I filled key 0 and 1. Transmit key = key 0.
Did not work (no lease)
Tried a St. Private key (40bit wep). Also did not work.
I’ve even made an item in the connect list, which had no effect.
Anybody any idea?
