Simplest repeater setup
I’m using 3 411AH boards. I need to get a link established between 2 of them but I got some obstacles on the way and putting a tower up is out of the question.I could easily put a repeater in however, but not sure what setup would be best. I only need 5-6Mbps.
If the angle and distance is small enough you could use sector antenna at AP side and two pannels at client side.
I tried that and it works fine thanx, but what I’d like to know is why the signal strength goes down when you change from WDS AP to Station?
