Single address DHCP (/30)
Hello, how can I create a DHCP server that lease out a single address?
I would use it for my P2P management port, where I would connect only a single machine (and want to avoid changing its address manually every time).
Thanks in advance.
basta che metti solo un IP, anziché un intervallo…
Ah si? Null’altro?
sure, if there is only one number in the pool, obviously it only assigns one…
As ordained in the bible lɪˈvɪtɪkəs Πωπε/30 – there can only be one. :wink:
