Single port EoIP?
How do you configure the Ethernet interface for EoIP?
Right now, I’ve got my RB450G set up with ether3-local through ether5-local set with a master-port of ether2-local - so the local LAN ports are switched. Dandy.
What I’d like to do is disconnect ether5-local and connect it - and only it - to an EoIP tunnel to another routerboard elsewhere (connected via L2TP. I’ll set the PPP secret to use a particular IP address so that the EoIP tunnel will find it).
Gah.
It’s always about 10 minutes after I post something I figure it out.
Create a bridge, add the EoIP tunnel and the Ethernet port desired to it (and set master-port to none, of course).
