So I finally set up WiFi for my home and it consist of hAP ax3 acting as an router on second floor and hAP ax2 acting as an AP/switch for downstairs wired devices.
I have multiple SSIDs and VLANs, and hAP ax3 only have one SSID, for my main network and it’s combined 2.4/5 GHz ax, ax2 have 3 SSIDs, one for main network, same as ax3, so combined 2.4/5 GHz ax and same SSID for both of them. One SSID for cameras and security related devices and another SSID for IoT devices.
I noticed that my devices loves to connect to the upstairs router instead of the ax2 downstairs… Devices even rather connect to the 2.4 GHz WiFi upstairs and have terrible speeds… I scanned my area and i choose channels so APs don’t overlaps. Here are configs for both devices. I don’t know where the problem is…
Downstairs ax2
# jan/03/1970 02:14:49 by RouterOS 7.7
# software id =
# model = C52iG-5HaxD2HaxD
# serial number =
add ingress-filtering=no name=bridge vlan-filtering=yes
set [ find default-name=ether1 ] comment=TRUNK
set [ find default-name=ether2 ] comment=VLAN40_IPTV
set [ find default-name=ether3 ] comment=VLAN20_SECURITY
set [ find default-name=ether4 ] comment=VLAN20_SECURITY
set [ find default-name=ether5 ] comment=VLAN88_HOME
/interface vlan
add interface=bridge name=VLAN20_SECURITY vlan-id=20
add interface=bridge name=VLAN30_IOT vlan-id=30
add interface=bridge name=VLAN40_IPTV vlan-id=40
add interface=bridge name=VLAN88_HOME vlan-id=88
/interface wifiwave2 security
add authentication-types=wpa2-psk,wpa3-psk name=HOME
add authentication-types=wpa2-psk name=IOT
add authentication-types=wpa2-psk name=CCTV
set [ find default-name=wifi1 ] channel.band=5ghz-ax .frequency=5180 .width=\
20/40/80mhz configuration.country=Croatia .mode=ap .ssid="Gazdin WiFi" \
disabled=no security=HOME
set [ find default-name=wifi2 ] channel.band=2ghz-ax .frequency=2462 .width=\
20mhz configuration.country=Croatia .mode=ap .ssid="Gazdin WiFi" \
add channel.band=2ghz-ax .width=20mhz configuration.country=Croatia .mode=ap \
.ssid=IoT disabled=no mac-address=XX:XX:XX:XX:XX:XX master-interface=\
wifi2 name=wifi3 security=IOT
.ssid=WiFi_CCTV disabled=no mac-address=XX:XX:XX:XX:XX:XX \
master-interface=wifi2 name=wifi4 security=CCTV
add bridge=bridge interface=ether1
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged \
interface=ether2 pvid=40
interface=ether3 pvid=20
interface=ether4 pvid=20
interface=ether5 pvid=88
interface=wifi1 pvid=88
interface=wifi2 pvid=88
interface=wifi3 pvid=30
interface=wifi4 pvid=20
/interface bridge vlan
add bridge=bridge tagged=ether1,bridge untagged=ether3,ether4,wifi4 vlan-ids=\
20
add bridge=bridge tagged=bridge,ether1 untagged=ether5,wifi1,wifi2 vlan-ids=\
88
add bridge=bridge tagged=bridge,ether1 untagged=ether2 vlan-ids=40
add bridge=bridge tagged=bridge,ether1 untagged=wifi3 vlan-ids=30
/system identity
set name=hAP_ax2_DB
Upstairs ax3
feb/19/2023 10:06:52 by RouterOS 7.6
# software id =
# model = C53UiG+5HPaxD2HPaxD
# serial number =
add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no comment=defconf name=bridge \
vlan-filtering=yes
set [ find default-name=ether1 ] comment=WAN
set [ find default-name=ether2 ] comment=TRUNK
set [ find default-name=ether3 ] comment=VLAN10_TEA_RADNI_PC
set [ find default-name=ether4 ] comment=VLAN88_HOME
/interface vlan
add interface=bridge name=VLAN10_TEA_PC vlan-id=10
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=HOME
set [ find default-name=wifi1 ] channel.band=5ghz-ax .frequency=5500 \
.skip-dfs-channels=10min-cac .width=20/40/80mhz configuration.country=\
Croatia .mode=ap .ssid="Gazdin WiFi" disabled=no security=HOME
set [ find default-name=wifi2 ] channel.band=2ghz-ax .frequency=2412 \
.skip-dfs-channels=10min-cac .width=20mhz configuration.country=Croatia \
add name=dhcp_pool1 ranges=10.10.10.2-10.10.10.5
add name=dhcp_pool2 ranges=10.10.20.2-10.10.20.150
add name=dhcp_pool3 ranges=10.10.30.2-10.10.30.254
add name=dhcp_pool4 ranges=10.10.40.2-10.10.40.50
add name=dhcp_pool5 ranges=10.10.88.2-10.10.88.254
add address-pool=dhcp_pool1 interface=VLAN10_TEA_PC lease-time=1d name=\
dhcp_VLAN10
add address-pool=dhcp_pool2 interface=VLAN20_SECURITY lease-time=1d name=\
dhcp_VLAN20
add address-pool=dhcp_pool3 interface=VLAN30_IOT lease-time=1d name=\
dhcp_VLAN30
add address-pool=dhcp_pool4 interface=VLAN40_IPTV lease-time=1d name=\
dhcp_VLAN40
add address-pool=dhcp_pool5 interface=VLAN88_HOME lease-time=1d name=\
dhcp_VLAN88
/port
set 0 name=serial0
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged \
interface=ether2
add bridge=bridge comment=defconf frame-types=\
admit-only-untagged-and-priority-tagged interface=ether3 pvid=10
admit-only-untagged-and-priority-tagged interface=ether4 pvid=88
admit-only-untagged-and-priority-tagged interface=ether5 pvid=88
admit-only-untagged-and-priority-tagged interface=wifi1 pvid=88
admit-only-untagged-and-priority-tagged interface=wifi2 pvid=88
set discover-interface-list=HOME
/ipv6 settings
set disable-ipv6=yes
add bridge=bridge tagged=bridge,ether2 untagged=wifi1,wifi2,ether4,ether5 \
vlan-ids=88
add bridge=bridge tagged=bridge untagged=ether3 vlan-ids=10
add bridge=bridge tagged=bridge,ether2 vlan-ids=20
add bridge=bridge tagged=bridge,ether2 vlan-ids=30
add bridge=bridge tagged=bridge,ether2 vlan-ids=40
add interface=VLAN10_TEA_PC list=LAN
add interface=VLAN20_SECURITY list=LAN
add interface=VLAN30_IOT list=LAN
add interface=VLAN40_IPTV list=LAN
add interface=VLAN88_HOME list=LAN
add interface=VLAN88_HOME list=HOME
add address=10.10.10.1/24 comment="VLAN10 _TEA_PC" interface=VLAN10_TEA_PC \
network=10.10.10.0
add address=10.10.20.1/24 comment=VLAN20_SECURITY interface=VLAN20_SECURITY \
network=10.10.20.0
add address=10.10.30.1/24 comment=VLAN30_IOT interface=VLAN30_IOT network=\
10.10.30.0
add address=10.10.40.1/24 comment=VLAN40_IPTV interface=VLAN40_IPTV network=\
10.10.40.0
add address=10.10.88.1/24 comment=VLAN88_HOME interface=VLAN88_HOME network=\
10.10.88.0
/ip dhcp-client
/ip dhcp-server lease
add address=10.10.10.0/24 gateway=10.10.10.1
add address=10.10.20.0/24 gateway=10.10.20.1
add address=10.10.30.0/24 gateway=10.10.30.1
add address=10.10.40.0/24 gateway=10.10.40.1
add address=10.10.88.0/24 gateway=10.10.88.1
set allow-remote-requests=yes
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/Zagreb
/system identity
set name=hAP_ax3_router
/tool mac-server
/tool mac-server mac-winbox
set allowed-interface-list=HOME
