Single WAN port and Multi subnet public IPs
hello,
if I have 3 subnet public IPs, like 111.22.22.22/28, 222.22.22.22/28, 333.22.22.22/28, and singel WAN port, so RouterOS support this conifg? like pfSens?
tks.
You can have as many addresses or subnets on one port as you want (well, there probably is some upper limit, but unlikely anything you could hit).
okay. so there will not cause Routing loop?
If the subnet are not overlaping will not be a problem.
Maybe you could have a layer2 problem looking in ARP table, the best practice is to use VLAN instead
How to config this?tks.
Some ISP give you links via VLAN, so you can put a VLAN for each link in MikroTik Router, similar as sub-interface in Cisco routers
got it, tks.
