Network description:
I have L009 series router and One WAN port connected to SIP trunk second port connected to broadband, third port is made LAN and connected to switch to make our local LAN.
Requirement:
Want to make and receive calls from soft phones on PCs in local LAN and also internet access through broadband
Configuration:
We have made NAT to route SIP traffic to specific IP of IP PBX and other traffic to PCs for internet but not able to achieve the same
Is this router advisable to meet the requirement?
if yes, pls suggest the configuration
There are some questions that you will need to answer before we can give you any help (we’ll probably have more questions later):
What sort of PBX are you using for your SIP trunk?
Do you have any VLANs configured on your network?
What version of RouterOS are you running?
Is the connected switch a managed device?
Please attach a copy of your (sanitized) MikroTik configuration so that we can see what you’ve already done (see instructions below). Thank you.
Backups are your friend. Always make a backup!
/system backup save encryption=aes-sha256 name=MyBackup
Please, export and attach your current config to your post if you want help with a config issue:
/export hide-sensitive file=MyConfig/export file=MyConfig
