This situation is happening quite often and I really have no idea how dangerous it can be. Anyone knows what is it, how to detect it and how to fight against it?
i’m guessing the x.x.48.x range is your IP range?
If it is sip coming into your network, just block it at your gateway/Firewall.
If you have SIP servers in your network, and you need to have sip open for them, look at Fail2ban, its a program for linux that monitors ports & if there is hacking it automatically adds a filter rule to IP tables.
Yes, it’s a public ip range on main routers and this is coming from outside. But, if I block 5060 and 5061 ports, how will it affect VOIP?
I see a LOT of SIP scanning activity now days on public IP ranges.
One trick we do is pickup any IPs trying to connect to things they shouldnt (like core routers) on port 5060 or 5061 and add them to a banned list for a minimun of 12 hours.
If you do this on your internet gateway its a good way to stop some of this “rubbish traffic”
We even leave an IP or two in our customer ranges as “Honeypot IPs” to do the same thing.
This can of course be applied for people scanning for SSH etc as well..
Just a side note, as for dangerous it can be very dangerous! we have thousands of dollars lost when hackers compromised our voip system and abused it…
Cheers
Do you have people registering to your voip servers from outside your network? If you do, then you have 2 options, have a safe list of IP’s that may access your voip servers, block everything else. Or if you have clients that have dynamic IP’s, then i recommend Fail2Ban for your servers.
With VOIP I mean skype and msn. I hope we didn’t misunderstood. There are no dedicated servers for VOIP or anything similar on a network if you mean that. So, If ports 5060 and 5061 gets locked, that won’t affect skype or msn and simple port blocking would do a trick? ![]()
@Wesley
There are no dynamic IP’s and there are just routers.
To my knowledge Skype and MSN don’t use port 5060 or 5061, so they should be fine if you block those ports.
what you get if you Disable
ip firewall service ports sip
That just disables the SIP inspection helper, and doesn’t block SIP as such.
Thank you all for help…
Added udp 5060-5061 port block on existing virus chain and there are packet drop. There are no more sip listings and skype works. So far, so good ![]()
But, it’s not functional solution. Is there any known way to make something similar detectable for udp connections? Maybe a script that will count is there connection attempt from one incoming ip to a multiple targets on network and to be applicable on ROS?
:EDIT
@maximan
Nice, but I can’t watch network 24/7 and wait will there any new ip will emerge ![]()
I need an universal solution for all of this.
Can you please post the rules used?
That would be great
I have spent couple of days, having studied a subject and other branches of a forum, haven’t found the ready solution, have as a result made itself thus.
Rules for blocking of SIP brute force activity.
add action=drop chain=input comment="Drop brute forcers" in-interface=ether1-gateway src-address-list=bf_blacklist
add action=drop chain=forward comment="Drop brute forcers - fw" in-interface=ether1-gateway src-address-list=bf_blacklist
add action=add-dst-to-address-list address-list=bf_blacklist address-list-timeout=15m chain=forward comment="BF detect 6 - sip - fw - add to block" content="SIP/2.0 401 Unauthorized" \
dst-address-list=bf_sip_stage5 in-interface=bridge-local log-prefix="BLOCK SIP FW BF" protocol=udp src-address=192.168.1.234 src-port=5060-5069
add action=add-dst-to-address-list address-list=bf_sip_stage5 address-list-timeout=1m chain=forward comment="BF detect 5 - sip - fw" content="SIP/2.0 401 Unauthorized" \
dst-address-list=bf_sip_stage4 in-interface=bridge-local protocol=udp src-address=192.168.1.234 src-port=5060-5069
add action=add-dst-to-address-list address-list=bf_sip_stage4 address-list-timeout=1m chain=forward comment="BF detect 4 - sip - fw" content="SIP/2.0 401 Unauthorized" \
dst-address-list=bf_sip_stage3 in-interface=bridge-local protocol=udp src-address=192.168.1.234 src-port=5060-5069
add action=add-dst-to-address-list address-list=bf_sip_stage3 address-list-timeout=1m chain=forward comment="BF detect 3 - sip - fw" content="SIP/2.0 401 Unauthorized" \
dst-address-list=bf_sip_stage2 in-interface=bridge-local protocol=udp src-address=192.168.1.234 src-port=5060-5069
add action=add-dst-to-address-list address-list=bf_sip_stage2 address-list-timeout=1m chain=forward comment="BF detect 2 - sip - fw" content="SIP/2.0 401 Unauthorized" \
dst-address-list=bf_sip_stage1 in-interface=bridge-local protocol=udp src-address=192.168.1.234 src-port=5060-5069
add action=add-dst-to-address-list address-list=bf_sip_stage1 address-list-timeout=1m chain=forward comment="BF detect 1 - sip - fw" content="SIP/2.0 401 Unauthorized" \
dst-address-list=!sip-auth in-interface=bridge-local protocol=udp src-address=192.168.1.234 src-port=5060-5069
add action=add-dst-to-address-list address-list=bf_blacklist address-list-timeout=15m chain=forward comment="BF detect 6 - sip - fw2 - add to block" content="SIP/2.0 404 Not Found" \
add action=add-dst-to-address-list address-list=bf_sip_stage5 address-list-timeout=1m chain=forward comment="BF detect 5 - sip - fw2" content="SIP/2.0 404 Not Found" dst-address-list=\
add action=add-dst-to-address-list address-list=bf_sip_stage4 address-list-timeout=1m chain=forward comment="BF detect 4 - sip - fw2" content="SIP/2.0 404 Not Found" dst-address-list=\
add action=add-dst-to-address-list address-list=bf_sip_stage3 address-list-timeout=1m chain=forward comment="BF detect 3 - sip - fw2" content="SIP/2.0 404 Not Found" dst-address-list=\
add action=add-dst-to-address-list address-list=bf_sip_stage2 address-list-timeout=1m chain=forward comment="BF detect 2 - sip - fw2" content="SIP/2.0 404 Not Found" dst-address-list=\
add action=add-dst-to-address-list address-list=bf_sip_stage1 address-list-timeout=1m chain=forward comment="BF detect 1 - sip - fw2" content="SIP/2.0 404 Not Found" dst-address-list=\
ether1-gateway - Internet interface
192.168.1.234 - SIP server in local net
“sip-auth” - address-list - IP of external provider SIP for the local SIP server
At the moment type of blocking following (after reboot)
