@CZFan - thanks for that. I tried disabling Fasttrack but it’s made no difference.
Please find config below:
# mar/10/2021 11:50:13 by RouterOS 6.48.1
# software id = DWNV-LDG5
# model = RouterBOARD 750G r3
# serial number = 6F3807E26367
add admin-mac=64:D1:54:75:A3:34 arp=proxy-arp auto-mac=no comment=\
"created from master port" name=bridge1 protocol-mode=none
set [ find default-name=ether1 ] speed=100Mbps
set [ find default-name=ether2 ] name=ether2-master speed=100Mbps
set [ find default-name=ether3 ] speed=100Mbps
set [ find default-name=ether4 ] speed=100Mbps
set [ find default-name=ether5 ] speed=100Mbps
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 keepalive-timeout=\
disabled name=PPPoE_WightWireless user=fwaxxxxxx@gointernet.co.uk
/interface l2tp-server
add name=l2tp-in1 user=andy.squibb
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
set [ find default=yes ] supplicant-identity=SUKL_Mikrotik
/ip ipsec profile
set [ find default=yes ] dh-group=modp1024 enc-algorithm=aes-256 \
hash-algorithm=sha256
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha256,sha1 enc-algorithms=\
aes-256-cbc,aes-128-cbc
add name=dhcp ranges=192.168.2.101-192.168.2.239
add name=dhcpVPN ranges=192.168.2.240-192.168.2.250
add address-pool=dhcp authoritative=after-2sec-delay disabled=no interface=\
bridge1 lease-time=1w3d name=defconf
/ppp profile
add bridge=bridge1 local-address=192.168.2.1 name=PPP_VPN remote-address=\
dhcpVPN
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,passw\
ord,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge=bridge1 interface=ether2-master
set discover-interface-list=discover
/interface l2tp-server server
set default-profile=PPP_VPN enabled=yes use-ipsec=yes
add interface=bridge1 list=discover
add interface=ether3 list=discover
add interface=ether4 list=discover
add interface=ether5 list=discover
add list=discover
add interface=bridge1 list=mactel
add interface=bridge1 list=mac-winbox
add address=192.168.2.1/24 comment=defconf interface=bridge1 network=\
192.168.2.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
/ip dhcp-server lease
add address=192.168.2.99 client-id=1:0:d0:2d:f6:ef:4 comment=Alarm mac-address=\
00:D0:2D:F6:EF:04 server=defconf
add address=192.168.2.66 client-id=1:b8:ca:3a:ba:1c:d mac-address=\
B8:CA:3A:BA:1C:0D server=defconf
add address=192.168.2.0/24 comment=defconf gateway=192.168.2.1 netmask=24
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.2.1 name=router
connection-state=established,related disabled=yes
add action=accept chain=forward comment="defconf: accept established,related" \
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid
add action=drop chain=input comment="DROP DNS" dst-port=53 in-interface=ether1 \
protocol=tcp
add action=accept chain=input dst-port=5060 in-interface=PPPoE_WightWireless \
protocol=tcp src-address=51.140.191.159
protocol=udp src-address=51.140.191.159
connection-state=new in-interface=ether1
add action=accept chain=input in-interface=ether1 protocol=ipsec-esp
add action=drop chain=input comment="DROP DNS" dst-port=53 in-interface=\
PPPoE_WightWireless protocol=udp
add action=drop chain=input protocol=icmp
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=drop chain=input dst-address=193.31.66.165 dst-port=80 in-interface=\
PPPoE_WightWireless protocol=tcp
add action=drop chain=input in-interface=ether1 protocol=tcp src-port=8080,80
add action=drop chain=input disabled=yes in-interface=ether1 log=yes
add action=masquerade chain=srcnat out-interface=PPPoE_WightWireless
add action=dst-nat chain=dstnat dst-port=10001 in-interface=PPPoE_WightWireless \
protocol=tcp to-addresses=192.168.2.99 to-ports=10001
protocol=udp to-addresses=192.168.2.99
add action=dst-nat chain=dstnat disabled=yes dst-port=5060,5061 in-interface=\
PPPoE_WightWireless protocol=tcp to-addresses=192.168.2.21
PPPoE_WightWireless protocol=udp to-addresses=192.168.2.21
add action=dst-nat chain=dstnat disabled=yes dst-port=5090 in-interface=\
add action=dst-nat chain=dstnat disabled=yes dst-port=9000-9049 in-interface=\
/ip firewall service-port
set sip disabled=yes
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/ip upnp
set enabled=yes
/ppp secret
add name=andy.squibb profile=PPP_VPN
/system clock
set time-zone-name=Europe/London
/system identity
set name=SUKL_Mikrotik
/system resource irq rps
set ether1 disabled=no
set ether3 disabled=no
set ether4 disabled=no
set ether5 disabled=no
set ether2-master disabled=no
/system routerboard settings
set auto-upgrade=yes
/system scheduler
add interval=1d name=3amReboot on-event="/system reboot" policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
start-date=nov/01/2018 start-time=03:00:00
add disabled=yes interval=5m name=WAN_checkalive on-event=\
"/system script run checkWAN" policy=\
start-date=jan/01/1970 start-time=00:00:00
/system script
add dont-require-permissions=no name="Restart ether1" owner=admin policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=":gl\
obal runningRestartEther1\
\n:if ([:len \\\$runningRestartEther1] = 0 || \$runningRestartEther1 = 0) do\
\n={\
\n /interface {\
\n :set runningRestartEther1 1\
\n :local o [find name=\\\"ether1\\\"]\
\n set \\\$o disabled=yes\
\n :delay 5\
\n set \\\$o disabled=no\
\n :delay 2\
\n :set runningRestartEther1 0\
\n }\
\n}"
add dont-require-permissions=no name=checkWAN owner=admin policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=":if\
\_([/ping 8.8.8.8 interface=PPPoE_WightWireless count=3] = 0) do={;\
\n:log info \"restarting WAN (ether1) interface\";\
\n[/interface disable ether1];\
\n:delay 5;\
\n[/interface enable ether1];\
\n}"
/tool graphing interface
add interface=PPPoE_WightWireless
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
/tool netwatch
add disabled=yes down-script=\
"/system scheduler set [find name=\\\"Restart ether1\\\"] disabled=yes" \
host=8.8.8.8 up-script=\
"/system scheduler set [find name=\\\"Restart ether1\\\"] disabled=no"
/tool sniffer
set streaming-server=0.0.0.0:sip
