I need to make sure that SIP has priority in the Mikrotik and on the network. I am attempting to assign a higher priority to SIP and lesser priority to everything else.
I have read quite a bit and understand the QOS but can not make it work. I don’t see a lot of information on troubleshooting this problem.
So this is what I have done.
I have a added the Layer 7 definitions to the Mikrotik (3.11)
The one for SIP is this
/firewall layer7-protocol add comment=“” name=sip regexp=“^(invite|register|cancel) sip[\t-\r -~]*sip/[0-2]\.[0-9]”
I added the mangle rule to mark the traffic.
/ip firewall mangle
add action=mark-connection chain=prerouting comment=“” disabled=no layer7-protocol=sip new-connection-mark=sip passthrough=yes
add action=mark-connection chain=prerouting comment=“” disabled=no new-connection-mark=other passthrough=yes
I have also tried the connection-type=sip
Then I went to the Queue and added the Priority. Most of this is default.
/queue type
set default kind=pfifo name=default pfifo-limit=50
set ethernet-default kind=pfifo name=ethernet-default pfifo-limit=50
set wireless-default kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set synchronous-default kind=red name=synchronous-default red-avg-packet=1000 red-burst=20 red-limit=60 red-max-threshold=50 red-min-threshold=10
set hotspot-default kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set default-small kind=pfifo name=default-small pfifo-limit=10
/queue tree
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=657000 name=Fiber packet-mark=“” parent=office priority=8 queue=ethernet-default
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=sip_queue packet-mark=sip parent=Fiber priority=1 queue=ethernet-default
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=other_traffic packet-mark=other parent=Fiber priority=8 queue=ethernet-default
/queue interface
set internal queue=ethernet-default
set external queue=ethernet-default
set irvine-office queue=ethernet-default
set ids_mirror queue=ethernet-default
set ether5 queue=ethernet-default
set ether6 queue=ethernet-default
From what I could find this is what I needed. I found much more complicated information for more complicated QOS but I just need to give SIP higher priority at this point.
When I monitor the Queue it says:
queued-packets: 0
queued-bytes: 0
No matter what. I can make SIP calls and I see no increase in the counters.
It there a way to figure how traffic is flowing to troubleshoot this. Like a debug mode like some of the cisco routers use to see where traffic is going in the router so I can see why it is not working. I have studied NUMEROUS documents on the topic in the forum and the MT docs and can not find a solution that I can make work.
Thanks for your time.
Tim
