SIP problem
Hi all,
I´ve noticed a problem with my sip devices.
All of them work for a couple of days and then they just stop working.
After a reboot, or swapping from router mode to bridging.
all starts working again. :frowning:
I´m getting a bit crazy of this I tried to open all ports but no better results yet.
I upload screenshots of all the routers on my network.
I have 1 public IP for the all the network and 4 people are using thise sip devices
The problem is probably that I don´t know how to open these ports properly on the mikrotik…
I hope someone here can explain me how to open them properly using winbox.
Isn´t there a simple way like on for example a Cisco router to open these ports?
And I´ve found this topic:
http://forum.mikrotik.com/t/how-to-open-a-port-using-winbox/23823/1
Here they tell this person that ¨most¨ ports are opened by default.
So what is my problem then?
Ports that need to be opened are:
5075-5076 TCP/UPD
16384-16482
Many thanks.
Nanostation - Mikrotik 1100AH - Hiltron(Gateway)
How is this network laid out ? All of these devices have different ips.
Try just the MikroTik with your sip reg ports specified in the services section (in your case 5075,5076.
Sent from my GT-I9100 using Tapatalk
Hi, have you tried to disable the “SIP helpers” on the Mikrotik and Ubnt device? That often solve those kind of problems…
Ubnt:
Enable NAT Protocol
Mikrotik
Service ports:disable SIP
http://www.voip-info.org/wiki/view/Routers+SIP+ALG
