since yesterday (Jan 6, 2023) I was on 6.47LT since Feb 21, 2021 on my RB1100AHx4.
I didn’t dare to upgrade because my Gigaset N510 IP PRO (VOIP DECT Gateway) didn’t register any more after upgrading the RB1100 to 6.48.1 (stable).
Yesterday I updated to 6.49.1 (stable) and the phone worked.
Needed a new Winbox then, but that also was fine.
Today I upgraded to 7.6 cause I want to use Wireguard.
Now the VOIP problem is back, it cannot login with provider.
Looks like an on-off-on problem, Microsoft-like …
Any ideas?
EDIT:
Seems that I didnt wait long enough.
After rebooting the N510 the connection works for 1-2 hours, then login is rejected.
So, to make this working again, I have to reset the Rb1100 to 6.47LT or FIND THE CAUSE.
The cause might be some timing issue.
I remember that I tried to contact Mikrotik support 2 yrs ago, bit didnt get a solution.
Maybe a hero is here in the forum ![]()
EDIT(2):
I downgraded the RB1100 to 6.48.6LT. It seems to work again. I dont dare to upgrade to the regular “stable” branch.
As a software developer, I suspect there must be a difference between the LT branch and the regular branch in the code.
EDIT(3):
If I want to use Wireguard (that was the only reason to upgrade), I need 7.x.
So I probably wait until a LT version is out, but this will probably never fix this problem.
EDIT(4):
There are 2 things that bother me with Mikrotik:
- The company’s support doesnt take me for serious ( I asked this question 2 yrs ago - and the problem persists)
- SIP is a unloved step-child at MT, generally (there is no PBX)
- German distributor FMS needed 3 weeks plus reminder to reply to my mail, which included the offer to PAY for support finding a solution
(and I then didnt even get a reply to that question in my mail)
Conclusion: Even though this old hardware (RB1100) is IMO still great,
though bugs are definitely not more frequent as on other systems which I support
and though newer MT hardware is very competitive,
but then, as the prices went massively up - even compared to the bigger brands,
such a failing support can’t motivate to use MT in professional context.
