I have two mikrotiks connected via SSTP, and the connection is established within the mikrotikas.
Mikrotik server is behind a modem/router combo and I can ping the server mikrotik without any trouble. Now I try to connect mikrotik to a PC via Ethernet so I can access the VPN connection. I can no longer ping the remote address from the PC and the PC does not take the server’s public IP.
I tried setting up a static route from client to server with no success, and I also tried routing marks but not sure if I set it up correctly.
SSTP VPN connection is established between the two MikroTik’s. My goal is to make the PC use server’s IP and Internet connection.
To do so, I tried setting up static route and marking packets but when I connect PC to MikroTik, it still uses its broadband internet.
Should I post my configuration?
DSL router forwards ports to the server MikroTik, client MikroTik is put in DMZ in broadband router.
