Could you please help me to configure mikrotik
I'm trying to pick between two IPsec routers. WAN via 3G modems. Accordingly, use dynamic IP. To automatically update IP-configuration are using DynDNS (script).
Configuration have listed below.
3G interent works but tunnel does not rise.
siteA
/system script
add name=dynamic-dns-script policy=
ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive source="\
User account info of DNSoMatic\r\
\n:global maticuser "ххххх"\r
\n:global maticpass "ххххх"\r
\n:global matichost "testtele2sitea.dyndns.org"\r
\n# No more changes need\r
\n\r
\n:global previousIP\r
\n\r
\n# Print values for debug\r
\n:log info "DNSoMatic: Updating dynamic IP on DNS for host $matichost"
\r
\n:log info "DNSoMatic: User $maticuser y Pass $maticpass"\r
\n:log info "DNSoMatic: Last IP $previousIP"\r
\n\r
\n# get the current IP address from the internet (in case of double-nat)\r
\n/tool fetch mode=http address="checkip.dyndns.org" src-path="/" dst-
path="/dyndns.checkip.html"\r
\n:local result [/file get dyndns.checkip.html contents]\r
\n\r
\n# parse the current IP result\r
\n:local resultLen [:len $result]\r
\n:local startLoc [:find $result ": " -1]\r
\n:set startLoc ($startLoc + 2)\r
\n:local endLoc [:find $result "" -1]\r
\n:global currentIP [:pick $result $startLoc $endLoc]\r
\n:log info "DNSoMatic: IP actual $currentIP"\r
\n\r
\n# Touching the string passed to fetch command on "src-path" option\r
\n:local str "/nic/update?hostname=$matichost&myip=$currentIP&wildcard
=NOCHG&mx=NOCHG&backmx=NOCHG"\r
\n\r
\n:if ($currentIP != $previousIP) do={\r
\n:log info "DNSoMatic: Update need"\r
\n:set previousIP $currentIP\r
\n:log info "DNSoMatic: Sending update $currentIP"\r
\n:log info [ :put [/tool fetch host=MT user=$maticuser password=$maticp
ass mode=http address="updates.dnsomatic.com" src-path=$str dst-path=$
matichost]]\r
\n:log info "DNSoMatic: Host $matichost updated on DNSoMatic with IP $c
urrentIP"\r
\n} else={\r
\n:log info "DNSoMatic: Previous IP $previousIP and current $currentIP
equal, no update need"\r
\n}"
/system scheduler
add comment="" disabled=no interval=10m name=dynamic-dns-schedule on-event=dynamic-dns-script
start-date=jan/01/1970 start-time=00:00:01
add action=accept chain=srcnat comment="NAT bypass" disabled=no dst-address=
192.168.0.0/16 out-interface=ppp-out1
add action=masquerade chain=srcnat comment="default PAT" disabled=no out-interface=
ppp-out1
/ip ipsec peer
add address=1.1.1.1/32 port=500 auth-method=pre-shared-key dh-group=modp1024
disabled=no dpd-interval=disable-dpd dpd-maximum-failures=1
enc-algorithm=3des exchange-mode=main generate-policy=no hash-algorithm=
md5 lifebytes=0 lifetime=1d nat-traversal=no proposal-check=obey secret=
test send-initial-contact=yes
/ip ipsec policy
add action=encrypt disabled=no dst-address=192.168.88.0/24 dst-port=any
ipsec-protocols=esp level=require priority=0 proposal=default protocol=
all sa-dst-address=2.2.2.2 sa-src-address=1.1.1.1 src-address=
192.168.87.0/24 src-port=any tunnel=yes
/system script
add name=dynamic-router-update policy=
:global LocalSite [:resolve testtele2sitea.dyndns.org]\r
\n:global RemoteSite [:resolve testtele2siteb.dyndns.org]\r
\n/ip ipsec policy set 0 sa-dst-address=$RemoteSite sa-src-address=$Loca
lSite\r
\n/ip ipsec peer set 0 address="$RemoteSite/32:500""
