Hello all,
I would like to know what exactly is a “slave interface” on router os parlance. I’ve googled, and this term does not seem to appear anywhere outside of mirkotik/routeros context.
This page http://wiki.mikrotik.com/wiki/Manual:Initial_Configuration for example talking about removing interfaces from a bridge and adding them as slaves to a single interface that is in a bridge.
Could you please explain what difference it makes and what a slave interface is?
As far as I understand on a very layman level of mine, a bridge combines interfaces for L2 routing so they do not have their own IP addresses. This is useful because from outside of the bridge it does not matter what interface inside the bridge your device is on (it can be connect to a wireless interface or another wireless interface or to Ethernet interface) you just set up your routing with the bridge and the bridge takes care of the rest.
In this respect I’m not sure what a slave interface is for… the end result seems to be the same?
