i want to make my RB750UPr2 a slave less port…but every time i configure the ether 3-5 to without master the connection lost…
can anybody give me the setup on this..
p.s. i want to block the all website in a certain port
thank you
thank you
You need to post your config. From the terminal do: /export compact hide-sensitive
Then paste the config here so we can see what you did.
actually I’m using the default setting configuration…nothing of it is changes…
Your LAN IP is configured on ether2. While port 3-5 are slaves they share ether2’s LAN IP. When you remove the slave option ports 3-5 are on their own and do not have a LAN IP.
