Slow Ethernet between hAP ac and SB8200
This issue is puzzling me and I’m struggling to figure out where the slowdown is coming from.
For starters:
  • Arris SB8200 Modem
  • RB962UiGS-5HacT2HnT hAP ac router
  • ROS 6.43.4, Firmware 6.43.4
  • 1Gb/s down - Comcast as ISP
  • PC connected to eth2 on the hAP with the modem on eth1.
  • Very basic setup no NAT rules other than masquerade, fast tracking established / related on the forward chain, no mangle or raw rules.
Currently I’m getting an average of 300 Mb/s down, I’ve seen as low as 180 and high as 560, but it’s inconsistent. The hAP’s CPU is showing around 30-40% use during the speed tests. Profiler shows networking / ethernet next below cpu0 with neither really breaking 10%. Confirmed the interface is showing 1Gb/s Full Duplex.
If I connect my PC direct to the modem I pull full advertised speeds and get around 960 Mb/s with the ethernet overhead.
If I connect a second PC to eth1 and have it act as a WAN (give out a DHCP address to the hAP which it then NATs to PC1 on eth2) and run a speed test between PC1 and PC2, I’m getting ~960 Mb/s with CPU hitting 80-90% use. No settings changed at all from when it was hooked up to the modem on eth1. Used the same cable from eth1 to PC2 as I did from eth1 to Modem.
Connecting PC2 back to eth3 I get full wirespeed between PC1 and PC2 with almost no CPU use as expected since it’s handled in the switch.
If I turn off DHCP client/server, plug modem into eth4 and just grab the modem’s DHCP from my PC (trying to use the hAP as a switch like above) I see the same ~300 Mb/s.
Any ideas on what is going on here? Something is just not playing nice with the connection between the SB8200 and the hAP and I can’t seem to track down what it is.
More confusion.
Grabbed a decommissioned RB1100AHx2 from the office and hooked that up to test. Same results, 250-300 Mb/s download speeds, this time barely scratching the CPU with less than 10% on either core.
Not even sure where to go from here, seems there is just something about ROS that the SB8200 doesn’t like.
Did you ever figure out the problem? I’ve got exactly the same issue. I have the same modem connected to a Microtik Cloud Router. Can’t get more than 400Mbps from computers connected to the router, but if I go directly to the modem (SB8200) I get 920Mbps.
Never did end up figuring it out, I picked up an RB4011 and that is able to run at full speed. If you’re using a CCR with the same issue then I wonder if the ARM CPU is the difference maker or something.
I have the RB450Gx4, very similar to the hapac2 and I have no issues grabbing the full 1gig service from my ISP?
