hello all … i have this issue since 2 weeks i dont know what is the problem i changed every think cables routers and switches … and etc…
i called my ISP to check if the problem from the VDSL thy come 3 time’s to my home and they said everything is okay from our side ![]()
my network : ISP → Mikrotik ( RouterBOARD 750G r2 ) → Tp-link switch (TL-SG1008D) → BL-WA310AP 300Mbps Wireless N AP/ Client Router
the lb-link router connected via pppoe i did not use hotspot ![]()
and this is my router config.
# mar/30/2018 12:53:52 by RouterOS 6.41.3
# software id = 56QK-DWPX
# model = RouterBOARD 750G r2
# serial number = 64FB04381671
add fast-forward=no name=bridge1
set [ find default-name=ether2 ] name=Local
set [ find default-name=ether5 ] name=WAN1
/ip hotspot profile
add dns-name=www.extreme.net hotspot-address=10.10.10.2 html-directory=\
flash/hotspot name=hsprof1
/ip hotspot
add disabled=no interface=bridge1 name=hotspot1 profile=hsprof1
add name=hs-pool-2 ranges=10.10.10.1,10.10.10.3-10.10.10.254
add address-pool=hs-pool-2 authoritative=after-2sec-delay disabled=no \
interface=bridge1 lease-time=1h name=dhcp1
/ppp profile
set *0 local-address=hs-pool-2 remote-address=hs-pool-2
add local-address=hs-pool-2 name=2mb rate-limit=2024k/2024k remote-address=\
hs-pool-2
add local-address=hs-pool-2 name=4mb rate-limit=4048k/4048k remote-address=\
hs-pool-2
add local-address=hs-pool-2 name=8MB rate-limit=4096k/8192k remote-address=\
hs-pool-2
add local-address=hs-pool-2 name=6mega rate-limit=6144k/6144k remote-address=\
hs-pool-2
add local-address=10.10.10.200 name=staticip rate-limit=4096k/8192k \
remote-address=10.10.10.200
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
/interface bridge filter
add action=log chain=input comment="Block DHCP servers on 192.168.0.0/16" \
dst-address=255.255.255.255/32 ip-protocol=udp log-prefix=\
"ALERT ROGUE DHCP (BLOCKED)" mac-protocol=ip src-address=192.168.0.0/16 \
src-port=67-68
add action=drop chain=input comment="Block DHCP servers on 192.168.0.0/16" \
dst-address=255.255.255.255/32 ip-protocol=udp mac-protocol=ip \
src-address=192.168.0.0/16 src-port=67-68
add bridge=bridge1 hw=no interface=Local
/interface bridge settings
set use-ip-firewall=yes use-ip-firewall-for-vlan=yes
/interface pppoe-server server
add disabled=no interface=bridge1 service-name=pppoe
add address=10.10.10.2/24 interface=bridge1 network=10.10.10.0
add address=5.5.5.2/24 interface=WAN1 network=5.5.5.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add add-default-route=no dhcp-options=hostname,clientid disabled=no \
interface=bridge1
add address=10.10.10.0/24 comment="hotspot network" gateway=10.10.10.2
set servers=8.8.8.8,8.8.4.4
add action=passthrough chain=unused-hs-chain comment=\
"place hotspot rules here" disabled=yes
add action=add-src-to-address-list address-list=Torrent-Conn \
address-list-timeout=none-dynamic chain=\
"address-list-timeout=2m chain=forward layer7-protocol=\\" disabled=yes
"address-list-timeout=2m chain=forward p2p=all-p2p src-address=\\" \
disabled=yes
add action=drop chain=forward disabled=yes dst-port=\
!0-1024,8291,5900,5800,3389,14147,5222,59905 protocol=tcp \
src-address-list=Torrent-Conn
!0-1024,8291,5900,5800,3389,14147,5222,59905 protocol=udp \
address-list-timeout=2m chain=forward disabled=yes layer7-protocol=*2 \
src-address=10.10.10.0/24 src-address-list=!allow-bit
address-list-timeout=2m chain=forward disabled=yes p2p=all-p2p \
add action=masquerade chain=srcnat comment="masquerade hotspot network" \
add action=masquerade chain=srcnat out-interface=bridge1
/ip hotspot user
add name=admin
add distance=1 gateway=5.5.5.1
/ip smb shares
set [ find default=yes ] directory=/pub
/ppp secret
add comment="200.200.200.200 gateway | 10.10.10.10" disabled=yes name=20 \
profile=2mb service=pppoe
add comment="\D3\C7\E3\CD \C7\E1\DE\D1\C9" name=33 profile=2mb service=pppoe
add comment="Gateway : 192.168.0.254 / internet sub : 17/2 | \E6\C7\D5\E1 50 \
\D4\ED\DF\E1 \E3\E4 185 \CD\DE \C7\DF\D3\D3 \C8\E6\ED\E4\CA" name=som3a \
profile=4mb service=pppoe
add comment="salah abo ryad | 192.168.1.1" name=salah profile=4mb service=\
pppoe
add comment="khalel sarsor 13.13.13.13" name=kh profile=2mb service=pppoe
add comment="Rami esa 42.42.42.42" name=44 profile=2mb service=pppoe
add comment="mohye 150.150.150.150 | gate : 150.150.150.1" name=50 profile=\
4mb service=pppoe
add comment="manal 16.16.16.16" name=80 profile=2mb service=pppoe
add comment="Helal : 100.100.100.100" name=10 profile=2mb service=pppoe
add name=q service=pppoe
add name=home profile=8MB service=pppoe
add comment="192.168.0.254 ||| date : 18/5 |||| \DB\ED\D1 \E6\C7\D5\E1 \CD\DE \
\C7\D3\D3 \C8\E6\ED\E4\CA 150 \D4\ED\DF\E1 + 13 \E3\CA\D1 \DF\ED\C8\E1" \
name=lo2ay profile=6mega service=pppoe
add comment=192.168.0.254 name=3 profile=4mb service=pppoe
add name=same7 profile=4mb service=pppoe
add name=700 profile=4mb service=pppoe
/system clock
set time-zone-name=Asia/Hebron
my internet speed is 50mb … after some houres i cant even open speedtest.net
and some devices is connected and work okay buy the other’s is not
can u help me please :
