Mikrotik 2011 is connected to internet thought FritzBox 7590, internet speed is 40mbs but in FritzBox (provider dsl router) is 250mbs.
What should I check?
without knowing much from your config, fasttrack rule in ip/firewall helps on this model. enable it. i have the same router with 100/10 mbps internet speed and works fine..
Fastpath will help a LOT but I doubt that a RB2011 will be able to do NAT at 250 mbps..
After 125-150 mbps depending on the router’s configuration, it simply didn’t have enough power to do the job..
RB2011 does well over 800Mbps with FastTrack.
If you don’t use the 100Mbps ports that is.
FastTrack in Filter rules & Fast Forward in Bridge is ON
The router was already with a fast path.
I have the same router in another office and everything works fine at a speed of 1 gigabit in both directions.
