My Interent Service Provider says my Router is slowing my internet down.
Has anybody else heard this?
What info do i need to provide so we can diagnose this?
cylent, more information required about ‘slowing my internet’.
Probably, you have queue,firewall configuration, that limit/block certain traffic.
i realize i need more information.
i am still new to RouterOS and would like you to tell me what info you want to see and i’ll happily provide it.
cylent, you have to give us more information about your current problem.
(Why your provider told that "Router is slowing my internet down ").
well when i disconnected the router and connected my laptop directly to my linkstar (satellite modem) i noticed pages loaded faster and my isp guy said he got a better ping and such
Disable queues, firewall rules on router and try to check how it will work.
If connection will be good (suitable).
Try to enable rules one by one in order to find incorrect configuration rule.
in Queues I have the following Simple Queue which i cant disable.
[admin@grnzne-inet] queue> simple
[admin@grnzne-inet] queue simple> print
0 D name="<hotspot1>" dst-address=0.0.0.0/0 interface=ether2 parent=none
direction=both priority=8 queue=hotspot-default/hotspot-default
limit-at=0/0 max-limit=0/0 total-queue=default-small
and in Firewall – NAT i have the following:
[admin@grnzne-inet] ip firewall nat> print
0 ;;; masquerade hotspot network
chain=srcnat src-address=192.168.0.0/24 action=masquerade
1 X ;;; masquerade hotspot network
2 X chain=dstnat in-interface=ether2 dst-address=0.0.0.80 protocol=tcp
action=redirect to-ports=8080
3 ;;; ;;; intercept all DNS requests
chain=dstnat protocol=udp dst-port=53 action=dst-nat
to-addresses=192.168.0.1 to-ports=0-65535
4 ;;; ;;; Transparent Proxy
chain=dstnat dst-address=192.168.0.1 protocol=tcp dst-port=80
action=redirect to-ports=3128
what else is there that you care to see?
It’s not a router issue!
It’s a problem with concurent tcp connections you can use over satellite.
When you disconnect router you also kill established tcp connections (free) and when you connect laptop your net is going fast.
These satellite links are not ment to be used for a lot of users, just few.
Go to ip firewall connection tracking and count how many established connections you have.
You can help a lot if you reduce established connections timeout to 1hour or 30 minutes and you’ll have a little improvement, but not much.
There is no router solution for your situation, sorry.
Cheers…
i dont understand what you mean.
