Slow LAN bandwidth
Hi all!
Sorry for my bad English.
I have a RB951G-2HnD router and a CRS226-24G-2S+RM cloud router switch.
I’m using the latest stable firmware (6.36) on this devices.
The router has a factory default configuration.
The cloud router switch has a factory default configuration also but I set “automatic IP acquisition” instead of the static 192.168.88.1.
I connected the RB951G-2HnD second port (LAN) with the CRS226 first port via a 10 meter length CAT5E factory made cable.
The CRS226 obtained the 192.168.88.253 IP address from the RB951G-2HnD.
I connected to the CRS226 second port my PC via a 2 meter length CAT5E factory made cable.
My PC obtained the 192.168.88.254 IP address from the RB951G-2HnD.
I think the measured TCP throughput is very slow in this typically basic configuration.
In the router (to the switch):
Tx: 54MBit/sec
Rx: 34MBit/sec
In the switch (to the router):
Tx: 31MBit/sec
Rx: 53MBit/sec
This values was the “Rx/Tx total average” -s.
I tried the measure in command line also, but no changes in the values. In the RB951G-2HnD to the CRS226:
[admin@MikroTik] /tool> bandwidth-test 192.168.88.253 user=admin direction=transmit protocol=tcp duration=10s
status: done testing
duration: 10s
tx-current: 47.0Mbps
tx-10-second-average: 54.9Mbps
tx-total-average: 54.9Mbps
random-data: no
direction: transmit
This values with UDP protocol was ten times faster: 540…560MBit/sec
Is this values is normal? I think not.
I think the normal throughput should near 1000MBit/sec. What do you recommend? What can I check? What is wrong? Or this is normal?
update: I tried the connection between the devices with an 1 meter length factory made CAT 6 cable too - but no changes in the measured values :frowning:
update2:
I installed to my Windows PC the Mikrotik Bandwidth Test 0.1 software.
My PC has a 1000MBit/sec network card.
The PC is connected to the CRS226 second port.
The bandwidth values to the RB951G-2HnD (across the CRS226):
Rx: 91,4MBps
Tx: 97,6MBps
The bandwidth values to the CRS226:
Rx: 11,7MBps
Tx: 33,9MBps
I don’t understand…
How can this values so slow from my PC to the CRS226? And from my PC to the router (across the CRS226!!!) how can 100MBit up/down?
All devices has only gigabit ethernet ports… very mystic…
Has anybody any idea or suggestion?
Check that on both sides of the ethernet link the layer2 is set to “auto”.
Don’t use fixed settings like 100 Mbit or FULL duplex. It will ruin your day.
Thanks your fast answer. Where can I find the layer2 settings? I did’n find anywhere :frowning:
If I choose the RB951’s ether2 interface I see this (general tab):
type: Ethernet (fix)
MTU: 1500
L2 MTU: 1598
Max L2 MTU: 4074 (fix)
MAC: mac add… (fix)
ARP: Enabled
Master port: none
Bandwidth Tx/Rx: none/none
Switch: switch1
The “fix” values I can’t modify.
Maybe the MTU / L2 MTU is not so good? This was the default values…
On the “ethernet” tab:
auto-negotiation is checked
Tx/Rx flow control: off/off
All advertised are checked.
This was the defaults also here.
A stupid question:
In the CRS226 “Quick set” I can choose the mode: “Router” or “Bridge”.
In this case (this was the default) the mode is “Router”. Maybe can I change to the “Bridge”? I want to use the CRS226 as a normal switch.
Or this is unaffected for my slow bandwidth problem?
