I am having issues with NAT. The setup is this:
Router Mikrotik CRS1128G4SIN
symetric 100Mbit internet —> ether1 → NAT → ether8 ->LAN
Speed tested with PC connected directly to internet: 80/90Mbits
Speed tested with the same PC connected to ehter8 (NAT) (disconnected from LAN): 40/45Mbits
The configuration is basic, created with quick set.
All connections are gigabit ethernet working on 1Gb full duplex. Tested also using sfp9 and fiber link to a gigabit switch of LAN: same speeds.
The CPU is 400Mhz and when I do a speed test, the CPU usage goes up to 100%.
The router can’t be so slow. .Anybody can tell me what may I be doing wrong please?
