Hi there.
I have a problem exactly the same as:
http://forum.mikrotik.com/t/pppoe-client-over-vlan-low-throughput-on-rb750gl/63579/1
My Set up
- Mikrotik - Routed network with a /30 over the VLAN it and I can max our 100/50M connection
- Miktotik - Run PPPoE over the VLAN and I get only about 50M/50M over the PPPoE Connection.
- Cisco 1921 - Routed Network with a /30 over the VLAN and can get 100/50 over it
- Cisco 1921 - Running PPPoE Client over the VLAN and can get 100M/50MM over the PPPoE Connection
I am testing on a CCR1008 with 6.19
It seems the PPPoE client on the Mikrotik is maxing out at around 50M thruput.
Any ideas.. I’ve heard in the past other people as well have problems with slow PPPoE Client on VLANS.
