Has anyone experienced slow responses from management of a mikrotik?
For example when you connect to the mikrotik Via winbox and pull up a window to look at interfaces it is very slow to load the list and even once it load it appears that the through put field only update every ten seconds.
My connection to the router itself does not appear to be the issue as I have internal access to the router so its not bandwidth. Even connect directly to the router is reports slow on everything.
Another example is that when I SSH into the unit and attempt to monitor a interfaces throughput. the screen only update every 10 seconds when it should be much more frequent.
After rebooting the router it seamed to resolve the issue so I’m not sure what fixed it.
Has anyone else had this same issue? I’m just curious if it is a known issue.
Also the CPU was not going over 6%
It’s a CCR1036-12G-4S running 6.5 OS. (I understand it is an older OS but we have not had any issues till this. I am curious if it is an OS issue)
