Hello!
I have my main router, Mk RB850Gx2, which is behind ISP Mikrotik router which has 1:1NAT setup.
I am having problems with connections from outside to inside. I tried bandwidth test with iperf3 from outside via dst-nat to client on inside, and speed I get is around 10Mbps.
Everything else works ok, download and upload speeds to outside on clients are ok (iperf and speedtest shows >200Mbps which is how it should be).
I have around 25filter and nat rules, is that a problem?
Most of NAT rules are dst-nat for port forwarding and same are for hairpin-nat.
I have around 50 clients on that router and 2 site-to-site vpn tunnels.
Hardware resources shows that CPU is around 10-20% busy and i have 400MB free RAM.
How should i troubleshoot this problem?
