Slow speed on second wan in dual wan configuration
I’ve got an RB750G configured with dual wan. I’ve got ports 1 and 2 connected to wans, and ports 3,4,5 as part of the switch. My WAN on port 2 is connected to a 20/200 connection but speed tests max out at 80-90mbps.
I just setup a mangle rule to send a specific host over port 2. Any suggestions on how to troubleshoot?
Any suggestions are appreciated.
What says profiler when maxing the throughput out?
Took a screenshot:
http://imgur.com/IYn2OQC
I can’t seem to get over 90mbps on port 2 on the 750G, I’ve plugged in a laptop and can easily do 100-200mbps. It’s connected to a motorola SB6183.
Im having the same issue, but on a CRS125
Need some help.
The download speed on WAN2 should be 120Mbits, but I get only between 50 and 60.
A funny thing, the WAN1 speed is 50 Mbits, as it should be.
Im using Port1 and Port2 on the Mikrotik, I wonder if the switch configuration on those ports has anything to do.
Tested with a Hex, dual WAN works great, 50Mbits on one port and 120Mbits on the other.
Im using prerouting mangle to mark packets coming from a particular LAN IP.
(I confirmed the traffic is going via WAN2 already)
Thanks’
