Got an RB750GL and have started setting it up.
I have ADSL modem plugged to the first interface on the router, my computer on 2, wireless AP on 3, switch on 4 and the server on 5. (Why are my computer and server switched? I was testing some unrelated problems. If this might be the problem, I’ll switch them.)
ADSL is 6M down and 1M up (Though speedtest says my up is 0.8M).
When I use internet from my computer everything works fine. Using wget on server also shows everything OK.
But, when I try sharing files between computers its very slow. Like 18Kbps slow. Before it was several Mbps in ethernet. Also, since winbox is running I can see that problem is not in the router CPU, its barely busy.
Server is Linux (with Samba and WINS), rest are Windows 7.
Any suggestions? Router settings are below:
0 address=192.168.0.128/24 network=192.168.0.0 interface=adsl
actual-interface=adsl
1 address=192.168.20.128/24 network=192.168.20.0 interface=mine
actual-interface=mine
2 address=192.168.30.128/24 network=192.168.30.0 interface=wifi
actual-interface=wifi
3 address=192.168.40.128/24 network=192.168.40.0 interface=switched
actual-interface=switched
4 address=192.168.10.128/24 network=192.168.10.0 interface=srvr
actual-interface=srvr
0 A S dst-address=0.0.0.0/0 gateway=192.168.0.1
gateway-status=192.168.0.1 reachable adsl distance=1 scope=30
target-scope=10
1 ADC dst-address=192.168.0.0/24 pref-src=192.168.0.128 gateway=adsl
gateway-status=adsl reachable distance=0 scope=10
2 ADC dst-address=192.168.10.0/24 pref-src=192.168.10.128 gateway=srvr
gateway-status=srvr reachable distance=0 scope=10
3 ADC dst-address=192.168.20.0/24 pref-src=192.168.20.128 gateway=mine
gateway-status=mine reachable distance=0 scope=10
4 ADC dst-address=192.168.30.0/24 pref-src=192.168.30.128 gateway=wifi
gateway-status=wifi reachable distance=0 scope=10
5 ADC dst-address=192.168.40.0/24 pref-src=192.168.40.128 gateway=switched
gateway-status=switched reachable distance=0 scope=10
0 R name="adsl" type="ether" mtu=1500 l2mtu=1598 max-l2mtu=4074
1 R name="wifi" type="ether" mtu=1500 l2mtu=1598 max-l2mtu=4074
2 R name="srvr" type="ether" mtu=1500 l2mtu=1598 max-l2mtu=4074
3 R name="mine" type="ether" mtu=1500 l2mtu=1598 max-l2mtu=4074
4 R name="switched" type="ether" mtu=1500 l2mtu=1598 max-l2mtu=4074
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s tcp-close-wait-timeout=10s \
tcp-established-timeout=1d tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s \
tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=accept chain=forward comment=NetBIOS disabled=no dst-port=135-139 protocol=udp
add action=accept chain=forward comment=NetBIOS disabled=no dst-port=135-139 protocol=tcp
/ip firewall mangle
add action=mark-connection chain=prerouting disabled=no new-connection-mark=p2p p2p=all-p2p passthrough=yes
add action=masquerade chain=srcnat disabled=no out-interface=adsl
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
