Slow speeds from CRS125
Hello everyone,
I am posting here because I need some help.
On a small client I do work for, I installed a Mikrotik CRS125.
They get their internet from a cable-internet provider, using an Arris TG862 modem.
The problem is:
When plugging my laptop via ethernet directly to the Arris modem, I get 88 Mbps download and 4 Mbps upload.
Which is really good.
If I then plug in the Mikrotik CRS125 into the Arris modem, then plug the laptop into one of the ethernet ports of the CRS, I get horrible internet speed – 2.9 Mbps down, 3.8 upload.
I attach the configuration of the CRS125 below.
There are a couple of things I have tried.
I tried to setup the Arris TG862 as “bridged”.
In the Arris I:
turned off the Firewall
DHCP server
set NAT mode as “Bridged”
went into the “WAN” setup and disabled DHCP
I then plug in the Mikrotik CRS125 into eth1 of the Arris, and give it a go.
Still get those horrible upload speeds.
I followed two instruction sets (pretty similar) to configure the Arris as Bridged, and try to not interfere with the connection (no NAT, no Firewall, etc.)
One of the instructions is the last post in this forum thread.
And another set (almost the same) is this video walk-through in YouTube.
Another test I did was to disable all the firewall rules I had set in the CRS125… the speed went up slightly (I think 8.0 Mbps download), yet still way below what it should be.
I copy/paste below the “export” of the Mikrotik CRS125 with the FW rules in-place and enabled.
Then below the CRS125 export with the FW rules disabled.
Here below the copy/paste of the config with the FW rules in-place and enabled.
[admin@MikroTik] > export
# mar/10/2016 18:05:58 by RouterOS 6.27
# software id = DE10-SLCQ
add admin-mac= auto-mac=no name=bridge-local
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-ht-above disabled=no distance=indoors frequency=auto l2mtu=2290 mode=ap-bridge ssid=theSSID \
    wireless-protocol=802.11
set [ find default-name=ether1 ] name=ether1-gateway
set [ find default-name=ether2 ] name=ether2-master-local
set [ find default-name=ether3 ] master-port=ether2-master-local name=ether3-slave-local
set [ find default-name=ether4 ] master-port=ether2-master-local name=ether4-slave-local
set [ find default-name=ether5 ] master-port=ether2-master-local name=ether5-slave-local
set [ find default-name=ether6 ] master-port=ether2-master-local name=ether6-slave-local
set [ find default-name=ether7 ] master-port=ether2-master-local name=ether7-slave-local
set [ find default-name=ether8 ] master-port=ether2-master-local name=ether8-slave-local
set [ find default-name=ether9 ] master-port=ether2-master-local name=ether9-slave-local
set [ find default-name=ether10 ] master-port=ether2-master-local name=ether10-slave-local
set [ find default-name=ether11 ] master-port=ether2-master-local name=ether11-slave-local
set [ find default-name=ether12 ] master-port=ether2-master-local name=ether12-slave-local
set [ find default-name=ether13 ] master-port=ether2-master-local name=ether13-slave-local
set [ find default-name=ether14 ] master-port=ether2-master-local name=ether14-slave-local
set [ find default-name=ether15 ] master-port=ether2-master-local name=ether15-slave-local
set [ find default-name=ether16 ] master-port=ether2-master-local name=ether16-slave-local
set [ find default-name=ether17 ] master-port=ether2-master-local name=ether17-slave-local
set [ find default-name=ether18 ] master-port=ether2-master-local name=ether18-slave-local
set [ find default-name=ether19 ] master-port=ether2-master-local name=ether19-slave-local
set [ find default-name=ether20 ] master-port=ether2-master-local name=ether20-slave-local
set [ find default-name=ether21 ] master-port=ether2-master-local name=ether21-slave-local
set [ find default-name=ether22 ] master-port=ether2-master-local name=ether22-slave-local
set [ find default-name=ether23 ] master-port=ether2-master-local name=ether23-slave-local
set [ find default-name=ether24 ] name=ether24-slave-local
set [ find default-name=sfp1 ] master-port=ether2-master-local name=sfp1-slave-local
/ip neighbor discovery
set ether1-gateway discover=no
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys wpa-pre-shared-key= wpa2-pre-shared-key=
add name=default-dhcp ranges=192.168.50.4-192.168.50.240
add name=PublicWiFi ranges=192.168.100.100-192.168.100.225
add address-pool=default-dhcp disabled=no interface=bridge-local name=default
add address-pool=PublicWiFi disabled=no interface=ether24-slave-local name=PublicWiFi
/port
set 0 name=serial0
/queue simple
add burst-time=10s/10s max-limit=1M/2M name=InternalWiFi target=wlan1
add max-limit=512k/2M name=PublicWiFi target=192.168.100.0/24 time=0s-1d,sun,mon,tue,wed,thu,fri,sat
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=wlan1
add address=192.168.50.1/24 comment="default configuration" interface=ether2-master-local network=192.168.50.0
add address=192.168.100.1/24 interface=ether24-slave-local network=192.168.100.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=no interface=ether1-gateway
/ip dhcp-server lease
add address=192.168.50.26 client-id=1:70:71:bc:ac:f6:73 mac-address= server=default
add address=192.168.50.4 client-id=1:34:17:eb:cb:30:a3 mac-address= server=default
add address=192.168.50.15 client-id=1:34:17:eb:ce:5a:3f mac-address= server=default
add address=192.168.50.7 client-id=1:d0:50:99:25:50:1f mac-address= server=default
add address=192.168.50.5 client-id=1:0:23:ae:9f:84:3 mac-address= server=default
add address=192.168.50.17 client-id=1:34:17:eb:c9:f6:11 mac-address= server=default
add address=192.168.50.13 client-id=1:f4:b7:e2:c1:9d:1b mac-address= server=default
add address=192.168.50.0/24 comment="default configuration" dns-server=192.168.50.1 gateway=192.168.50.1
add address=192.168.100.0/24 dns-server=192.168.100.1 gateway=192.168.100.1
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.50.1 name=router
add action=drop chain=input comment="Public WiFi block everything coming into the Mikrotik's .50.1" dst-address=192.168.50.1 src-address=192.168.100.0/24
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=established,related
add action=drop chain=input comment="default configuration" in-interface=ether1-gateway
add chain=forward comment="default configuration" connection-state=established,related
add action=drop chain=forward comment="default configuration" connection-state=invalid
add action=drop chain=forward comment="default configuration" connection-nat-state=!dstnat connection-state=new in-interface=ether1-gateway
add action=drop chain=forward comment="Public WiFi block everything coming into the office 192.168.50.0/24 network." dst-address=192.168.50.0/24 src-address=\
    192.168.100.0/24
add action=masquerade chain=srcnat comment="default configuration" out-interface=ether1-gateway
/system clock
set time-zone-name=America/Puerto_Rico
/system routerboard settings
set protected-routerboot=disabled
/tool mac-server
add interface=ether2-master-local
add interface=ether3-slave-local
add interface=ether4-slave-local
add interface=ether5-slave-local
add interface=ether6-slave-local
add interface=ether7-slave-local
add interface=ether8-slave-local
add interface=ether9-slave-local
add interface=ether10-slave-local
add interface=ether11-slave-local
add interface=ether12-slave-local
add interface=ether13-slave-local
add interface=ether14-slave-local
add interface=ether15-slave-local
add interface=ether16-slave-local
add interface=ether17-slave-local
add interface=ether18-slave-local
add interface=ether19-slave-local
add interface=ether20-slave-local
add interface=ether21-slave-local
add interface=ether22-slave-local
add interface=ether23-slave-local
add interface=ether24-slave-local
add interface=sfp1-slave-local
add interface=wlan1
add interface=bridge-local
/tool mac-server mac-winbox
add interface=wlan1
[admin@MikroTik] >
The config of the Mikrotik CRS125 with the FW rules disabled.
# mar/10/2016 18:08:41 by RouterOS 6.27
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=\
    20/40mhz-ht-above disabled=no distance=indoors frequency=auto l2mtu=2290 \
    mode=ap-bridge ssid=theSSID wireless-protocol=802.11
set [ find default-name=ether3 ] master-port=ether2-master-local name=\
    ether3-slave-local
set [ find default-name=ether4 ] master-port=ether2-master-local name=\
    ether4-slave-local
set [ find default-name=ether5 ] master-port=ether2-master-local name=\
    ether5-slave-local
set [ find default-name=ether6 ] master-port=ether2-master-local name=\
    ether6-slave-local
set [ find default-name=ether7 ] master-port=ether2-master-local name=\
    ether7-slave-local
set [ find default-name=ether8 ] master-port=ether2-master-local name=\
    ether8-slave-local
set [ find default-name=ether9 ] master-port=ether2-master-local name=\
    ether9-slave-local
set [ find default-name=ether10 ] master-port=ether2-master-local name=\
    ether10-slave-local
set [ find default-name=ether11 ] master-port=ether2-master-local name=\
    ether11-slave-local
set [ find default-name=ether12 ] master-port=ether2-master-local name=\
    ether12-slave-local
set [ find default-name=ether13 ] master-port=ether2-master-local name=\
    ether13-slave-local
set [ find default-name=ether14 ] master-port=ether2-master-local name=\
    ether14-slave-local
set [ find default-name=ether15 ] master-port=ether2-master-local name=\
    ether15-slave-local
set [ find default-name=ether16 ] master-port=ether2-master-local name=\
    ether16-slave-local
set [ find default-name=ether17 ] master-port=ether2-master-local name=\
    ether17-slave-local
set [ find default-name=ether18 ] master-port=ether2-master-local name=\
    ether18-slave-local
set [ find default-name=ether19 ] master-port=ether2-master-local name=\
    ether19-slave-local
set [ find default-name=ether20 ] master-port=ether2-master-local name=\
    ether20-slave-local
set [ find default-name=ether21 ] master-port=ether2-master-local name=\
    ether21-slave-local
set [ find default-name=ether22 ] master-port=ether2-master-local name=\
    ether22-slave-local
set [ find default-name=ether23 ] master-port=ether2-master-local name=\
    ether23-slave-local
set [ find default-name=sfp1 ] master-port=ether2-master-local name=\
    sfp1-slave-local
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=\
add address-pool=PublicWiFi disabled=no interface=ether24-slave-local name=\
    PublicWiFi
/port
set 0 name=serial0
/queue simple
add burst-time=10s/10s disabled=yes max-limit=1M/2M name=InternalWiFi target=\
    wlan1
add disabled=yes max-limit=512k/2M name=PublicWiFi target=192.168.100.0/24 \
add address=192.168.50.1/24 comment="default configuration" interface=\
add address=192.168.100.1/24 interface=ether24-slave-local network=\
    192.168.100.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=\
add address=192.168.50.26 client-id=1:70:71:bc:ac:f6:73 mac-address=\
    70:71:BC:AC:F6:73 server=default
add address=192.168.50.4 client-id=1:34:17:eb:cb:30:a3 mac-address=\
    34:17:EB:CB:30:A3 server=default
add address=192.168.50.15 client-id=1:34:17:eb:ce:5a:3f mac-address=\
    34:17:EB:CE:5A:3F server=default
add address=192.168.50.7 client-id=1:d0:50:99:25:50:1f mac-address=\
    D0:50:99:25:50:1F server=default
add address=192.168.50.5 client-id=1:0:23:ae:9f:84:3 mac-address=\
    00:23:AE:9F:84:03 server=default
add address=192.168.50.17 client-id=1:34:17:eb:c9:f6:11 mac-address=\
    34:17:EB:C9:F6:11 server=default
add address=192.168.50.13 client-id=1:f4:b7:e2:c1:9d:1b mac-address=\
    F4:B7:E2:C1:9D:1B server=default
add address=192.168.50.0/24 comment="default configuration" dns-server=\
/ip dns static
    "Public WiFi block everything coming into the Mikrotik's .50.1" disabled=\
    yes dst-address=192.168.50.1 src-address=192.168.100.0/24
add chain=input comment="default configuration" disabled=yes protocol=icmp
add chain=input comment="default configuration" connection-state=\
    established,related disabled=yes
add action=drop chain=input comment="default configuration" disabled=yes \
add chain=forward comment="default configuration" connection-state=\
add action=drop chain=forward comment="default configuration" \
    connection-state=invalid disabled=yes
    connection-nat-state=!dstnat connection-state=new disabled=yes \
add action=drop chain=forward comment="Public WiFi block everything coming int\
    o the office 192.168.50.0/24 network." disabled=yes dst-address=\
    192.168.50.0/24 src-address=192.168.100.0/24
add action=masquerade chain=srcnat comment="default configuration" \
/system clock
/tool mac-server
add interface=wlan1
add interface=wlan1
[admin@MikroTik] >
Where am I messing up?
Any help?
How can I get the Mikrotik CRS125 to take advantage of speed the Arris is providing?
Eagerly awaiting for your feedback!
Thank you!
Try disabling any simple queues and changing the WAN port interface queue type as per http://forum.mikrotik.com/t/crs125-24g-1s-2hnd-6-33-3-interface-queue-change-slowdown/94188/1
Strange. My crs125 provides 500Mbs have you tried the default configuration?
You should definitely be able to push more than 20 mbps through NAT, but remember, the CRS is designed primarily as a switch, not a router, so you’re only going to get so much out of it at layer 3.
You can find the solution here: http://forum.mikrotik.com/t/crs125-24g-1s-2hnd-in-vlan-preformance-from-wiki/84210/1
You need to change your queue type settings from from only-hardware-queue to default-ethernet. That will do the trick, good luck
Alex
But on the other side the only hardware queue should be the one that supports the fasttrack…
So far, I have changed the Queue type (Queues → Interface Queues) on ether2-master-local to “ethernet-default”.
The download is still very slow (3.2 Mpbs).
I then also changed ether1-gateway to queue type “ethernet-default”, and the download is still slow (3.4 Mbps).
Looking now to see if I downgrade to 6.32.4 (as per this post), via downloading it from Mikrotik’s Downloads page.
Will update soon.
Update:
With ether1-dateway set with Queue Type as “ethernet-default”, and ether2-master-local set as “only-hardware-queue”, the download speed now runs at 22 Mbps
Much better than before.
Still not the 88 Mbps that the Arris modem is pushing, yet definitely improved.
I still have not done a “downgrade” to version 6.32.4… do you guys think I should give it a try?
Thank you!
One more update:
Well, without any changes, the download is now running at 32.4 Mbps
If you guys have any additional feedback and suggestions, please let me know!
I would check the MTU and MSS of your WAN too - just to be sure…
  1. download MTUPATH.EXE ( http://www.iea-software.com/products/mtupath.cfm ) and see what the results for MSS are;
  2. download MTUROUTE.EXE (http://www.elifulkerson.com/projects/mturoute.php ) and see what it finds
It may be a VLAN is present at the ARRIS reducing your WAN to 1492 instead of 1500 and causing fragmentation ?
Smells like bufferbloat, try forcing the Arris to 100Mbps Full Duplex.. As well as the MikroTik ofcourse.
You could also configure auto negotiation to only advertise 100Mbps Full Duplex.
Best regards,
Menno
Thanks for the help!
Here are the results for mturoute:
And here is the mtupath results:
Can I force this from the Mikrotik?
The Arris’ interface does not have a lot of options… and I haven’t seen an option for Full Duplex, etc.
Thank you!
If you run a recent RouterOS, you should be able to control what speeds you are advertising.. Its under the ‘Ethernet’ tab under the interface connected to the Arris. Just advertise 100full only and see of it helps :smiley:
Menno
One theory down :confused: At least we know it’s not that :slight_smile:
Ps. Only use this as a workaround, when you for some reason want to force certain speeds, you should try your best in forcing it on both devices. When that’s not possible, you can resort to this mentioned ‘procedure’ :smiley:
Ok!
Did that… Went into ether1-gateway, Ethernet tab… and checkmark ON only on 100M full.
Download speed tests are showing as:
18.6 Mbps download, 4.3 Mbps upload
Yes!
And thank you for the help!
I greatly appreciate it.
Thanks for your reply, no bufferbloat here then..
Just for the sake of … can you put a switch between the Arris and the MT? Just a dumb one would do..
I have one if these guys - Linksys wrt120n
Will that work?
I have left the client’s physical offices for the day… yet I hope to be back tomorrow.
How would you connect this small switch?
Now I am thinking that maybe, for testing, setup the CRS125 to just be a switch, and have the Arris hand-out IPs (DHCP serveR).
What do you guys think?
Oh no :wink:, don’t you have a small real switch or something?, this will only complicate things :smiley: .. a normal ‘dumb’ switch will do in this case.
I doubt letting the Arris do the DHCP etc will help, what you are doing should be totally possible. Can you see high CPU on the CRS whilst downloading/speedtesting?
Best regards,
Menno
Hello Menno,
The other equipment I have is a Mikrotik RG951, and a hub (not a switch).
I haven’t paid attention to the CPU as I do the speed tests.
Will do a test today in the afternoon and report back.
I am thinking that maybe I messed-up something in the CRS125 when I initally configured it. Maybe to factory-scratch it and try again would be worthwhile.
Will report back asap.
Thank you!
