Slow speeds with - RB751G-2HnD
this is my first post here and i have tried to Google, search this forum and so on but i might be that i’m using the wrong keywords or something because i cant find any solution to my problem.
The problem is, i bought a RB751G-2HnD about one year ago, i’m very satisfied with it because it gives me all the options i need and want. The problem started when i got my new internet connection, a neat upgrade from 16/1 to 200/10 Mbps. I tried running speedtests but i only got ~75/11 which is very slow if you look at what i’m supposed to get.
So i tried to hook my PC into the modem, i got around 180/11 so i thought ok, strange. I have not really cared to fix it untill today when i pretty fast found out that the CPU hits 100% during the speed test and thereby giving me theese slow speeds. Now i’m wondering how this can be, if i look at different tests the router should be able to give me 400-600Mbps.
So does anyone here know if this is the actual limitation ~75Mbps or may i have some setting or feature in use that can make this happen?
