Slow throughput when using dynamic address list
Hi guys,
I have RB2011UiAS installed at a customer and he requested blocking of facebook and youtube. What I did was use the new feature of dynamic address list to create a couple of rules that do the blocking. From what I see the unit is not showing any high CPU etc.
This feature is new in 6.36. When you go to address list in firewall and add an address you can put the domain instead of the IP address and it will resolve it for you and refresh based on its TTL.
The command is:
/ip firewall address-list
add address=www.facebook.com list=facebook
add address=youtube.com list=Youtube
add address=facebook.com list=facebook
This works great as it will get all the ip´s for that domain that are registered on your internet facing dns servers (youtube comes up with 12 address for me..).
The firewall block rule is:
add action=drop chain=forward comment=Block-Youtube dst-address-list=Youtube log-prefix=“” src-address-list=Hotspot
add action=drop chain=forward comment=Block-Facebook dst-address-list=facebook log-prefix=“” src-address-list=Hotspot
This works fine and does block the access to the sites.
The problem is that the users the are subject to the rule ( src-address-list=Hotspot ip range x.x.x.5-x.x.x.120) navigate very slowly. while the users not subjetc to the rules (x.x.x.130-200) navigate very fast.
Any help or insights would be apreciated. Below is the full config:
aug/24/2016 11:47:26 by RouterOS 6.36
add admin-mac=E4:8D:8C:05:46:79 auto-mac=no comment=LAN name=bridge
set [ find default-name=ether1 ] advertise=10M-half,10M-full,100M-half,100M-full auto-negotiation=no comment=WAN
set [ find default-name=ether2 ] name=ether2-master
set [ find default-name=ether3 ] master-port=ether2-master
set [ find default-name=ether4 ] master-port=ether2-master
set [ find default-name=ether5 ] master-port=ether2-master
set [ find default-name=ether6 ] name=ether6-master
set [ find default-name=ether7 ] master-port=ether6-master
set [ find default-name=ether8 ] master-port=ether6-master
set [ find default-name=ether9 ] master-port=ether6-master
set [ find default-name=ether10 ] master-port=ether6-master
/ip neighbor discovery
set ether1 comment=WAN discover=no
set bridge comment=LAN
/ip hotspot profile
add hotspot-address=10.80.240.1 html-directory=Hotspot name=hsprof1
/ip hotspot user profile
set [ find default=yes ] shared-users=100
add name=dhcp ranges=10.80.248.5-10.80.248.120
add address-pool=dhcp disabled=no interface=bridge lease-time=1h name=dhcp1
/ip hotspot
add address-pool=dhcp disabled=no interface=bridge name=hotspot1 profile=hsprof1
add bridge=bridge comment=defconf interface=ether2-master
add bridge=bridge comment=defconf interface=ether6-master
add bridge=bridge comment=defconf interface=sfp1
add address=10.80.248.1/24 comment=“hotspot network” interface=ether2-master network=10.80.248.0
add address=x.x.x.x/29 interface=ether1 network=x.x.x.x
/ip dhcp-server lease
add address=10.80.248.50 client-id=1:b0:c0:90:61:3:8f mac-address=B0:C0:90:61:03:8F server=dhcp1
add address=10.80.248.51 client-id=1:b0:c0:90:69:15:5b mac-address=B0:C0:90:69:15:5B server=dhcp1
add address=10.80.248.132 client-id=1:54:35:30:20:e5:67 mac-address=54:35:30:20:E5:67 server=dhcp1
add address=10.80.248.0/24 comment=“hotspot network” gateway=10.80.248.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=10.80.248.1 name=router
add address=10.80.248.0/25 list=Hotspot
add action=accept chain=input dst-port=8291 log-prefix=“” protocol=tcp
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
add action=accept chain=input comment=“defconf: accept established,related” connection-state=established,related
add action=drop chain=input comment=“defconf: drop all from WAN” in-interface=ether1
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack” connection-state=established,related
add action=accept chain=forward comment=“defconf: accept established,related” connection-state=established,related
add action=drop chain=forward comment=“defconf: drop invalid” connection-state=invalid
add action=drop chain=forward comment=“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat connection-state=new in-interface=ether1
add action=passthrough chain=unused-hs-chain comment=“place hotspot rules here” disabled=yes
add action=masquerade chain=srcnat comment=“defconf: masquerade” out-interface=ether1
add action=masquerade chain=srcnat comment=“masquerade hotspot network” log-prefix=“” src-address=10.80.248.0/24
/ip hotspot user
add name=invitado password=invitado
add distance=1 gateway=x.x.x.x
/system routerboard settings
set protected-routerboot=disabled
/tool bandwidth-server
set authenticate=no
/tool graphing interface
add interface=ether1
/tool graphing resource
add
/tool mac-server
add interface=bridge
/tool mac-server mac-winbox
Change your action from “drop” to “reject”, as otherwise the browser will wait for the timeout.
