First, thanks for your input so far!
I am located at Moraira/Spain. The provider peers to Cogent3 at Valencia/Spain.
The line is rated 1000/1000 and in the past speed was around 900/900.
The fiber modem is directly connected to the RB5009. Because of DHCP the MTU is 1500.
Testing with Mikrotik Bandwidth Test against my Mikrotik router in Germany gives me around 50/50.
Testing from a Browser against:
https://www.movistar.es/test-de-velocidad/
https://librespeed.org
https://www.nperf.com
They all show me around 50/50.
Then I installed a VPS at Valencia and installed iperf3 and LibreSpeed on it.
Both show me around 50/50.
Then I ran Ookla Speedtest. Either the Ookla Linux command line speedtest or the public domain speedtest-cli or from a browser against https://www.speedtest.net give me speed above 800/800.
Here is the output of the “fast” speedtest:
root@srv-esp:~# speedtest -p
Speedtest by Ookla
Server: BIARTEL - Biar (id: 18815)
ISP: Closeness SL
Idle Latency: 9.54 ms (jitter: 0.76ms, low: 8.54ms, high: 10.38ms)
Download: 892.18 Mbps (data used: 908.0 MB)
25.06 ms (jitter: 1.70ms, low: 8.71ms, high: 34.87ms)
Upload: 861.63 Mbps (data used: 782.1 MB)
14.27 ms (jitter: 2.12ms, low: 8.65ms, high: 36.71ms)
Packet Loss: 0.0%
And the traceroute to the server used:
root@srv-esp:~# traceroute speedtest1.biartel.es
traceroute to speedtest1.biartel.es (78.41.80.11), 30 hops max, 60 byte packets
1 router-esp.esp (10.3.0.9) 0.202 ms 0.140 ms 0.162 ms
2 10.199.255.1 (10.199.255.1) 2.482 ms 2.403 ms 2.522 ms
3 10.254.254.1 (10.254.254.1) 6.460 ms 10.254.254.5 (10.254.254.5) 6.478 ms 6.463 ms
4 * * *
5 be8497.ccr31.vlc02.atlas.cogentco.com (154.54.39.173) 7.531 ms 7.220 ms 7.586 ms
6 wifiber.demarc.cogentco.com (149.14.4.202) 6.686 ms 6.629 ms 6.607 ms
7 5.180.229.111.core.valencia.spainwisp.com (5.180.229.111) 8.817 ms 9.274 ms 9.284 ms
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
And this a traceroute to the “slow” LibreSpeed test server:
[admin@router-esp] /tool> traceroute 31.14.238.88
ADDRESS LOSS SENT LAST AVG BEST WORST STD-DEV STATUS
10.199.255.1 0% 4 2.8ms 2.7 1.9 3.5 0.6
10.254.254.5 0% 4 5.5ms 5.8 5.5 6.3 0.3
10.121.102.1 0% 4 14.3ms 14.5 14.3 14.7 0.2
100% 4 timeout
100% 4 timeout
100% 4 timeout
100% 4 timeout
185.111.185.45 0% 3 18.8ms 19.7 18.8 20.6 0.7
31.14.238.88 0% 3 18.8ms 19.9 18.8 20.8 0.8
