Recently I upgrade to 4Gbps broadband and I used the CCR2004-1G-12S+2XS as router.
Here is the network architecture.
ONT-----CCR2004-----Mellanox 6012------PC(Windows 10, 1Gbps Intel 212 on motherboard and Mellanox MCX454A-FCAT at 40Gbps)、Mac(Hacintosh, Intel 10Gbps)、NAS (Linux, 40Gbps Mellanox CX354A FCCT)
By testing via Speedtest, downloading was around 3000Mbps, but uploading was weird.
It was only 120Mbps on my PC and 600Mbps on my Linux NAS, while it could reach 2800Mbps on Mac.
I also tested the Intel 212 adapter on PC. It reached 900Mbps on uploading without any issue. The file transfer from Windows 10 to NAS was 20Gbps.
I tried to remove the CCR2004 and use the ONT as the gateway(router), the uploading speed on PC and NAS are more than 2000Mbps.
It seems to be something wrong between CCR2004 and mellanox adapters? Please advise.
Here is my export.
# nov/09/2020 01:15:01 by RouterOS 6.47.7
# software id = D4N6-4W3Q
# model = CCR2004-1G-12S+2XS
# serial number = D4F00CCB288D
add name=bridge1 priority=0x1000
set [ find default-name=sfp-sfpplus1 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full,10000M-full auto-negotiation=no rx-flow-control=on speed=10Gbps tx-flow-control=on
set [ find default-name=sfp-sfpplus2 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full,10000M-full auto-negotiation=no rx-flow-control=on speed=10Gbps tx-flow-control=on
/interface vlan
add interface=sfp-sfpplus1 name=vlan10 vlan-id=10
add name=WAN
add name=LAN
add name=dhcp ranges=192.168.1.100-192.168.1.200
add address-pool=dhcp disabled=no interface=bridge1 name=dhcp1
/user group
set full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,dude,tikapp
add bridge=bridge1 interface=sfp-sfpplus2
add bridge=bridge1 interface=sfp-sfpplus3
add bridge=bridge1 interface=sfp-sfpplus4
add bridge=bridge1 interface=sfp-sfpplus5
add bridge=bridge1 interface=sfp-sfpplus6
add bridge=bridge1 interface=sfp-sfpplus7
add bridge=bridge1 interface=sfp-sfpplus8
add bridge=bridge1 interface=sfp-sfpplus9
add bridge=bridge1 interface=sfp-sfpplus10
add bridge=bridge1 interface=sfp-sfpplus11
add bridge=bridge1 interface=sfp-sfpplus12
add interface=vlan10 list=WAN
add address=192.168.1.1/24 interface=ether1 network=192.168.1.0
/ip dhcp-client
add disabled=no interface=vlan10
/ip dhcp-server lease
add address=192.168.1.7 client-id=ff:b9:12:28:f3:0:2:0:0:ab:11:5c:77:65:cc:4b:84:1a:10 mac-address=00:02:C9:ED:4C:72 server=dhcp1
add address=192.168.1.6 mac-address=00:02:C9:ED:4C:71 server=dhcp1
add address=192.168.1.5 client-id=ff:5d:e2:6c:15:0:2:0:0:ab:11:6e:64:62:27:9e:5e:14:73 mac-address=4C:CC:6A:44:DF:79 server=dhcp1
add address=192.168.1.8 mac-address=30:9C:23:A5:02:5E server=dhcp1
add address=192.168.1.0/24 gateway=192.168.1.1 netmask=24
set allow-remote-requests=yes
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
/ip service
set telnet disabled=yes
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=vlan10 type=external
add interface=bridge1 type=internal
/system clock
set time-zone-name=Pacific/Auckland
/system identity
set name=MikroTik2004
