Hi all, recently VLANned my home network and installed a CCR2004 at the same time. I am seeing some issues with TCP transfer rate.
Concerned flow:
Win 11 desktop Intel SFP+ <— 10g DAC → CRS310 <—10g DAC ----> CCR2004 <—10G RJ45 —> Google Fiber modem
When I connect the desktop directly to google fiber modem, DL happens at nearly wire speed, consistent ~215MBps:
When desktop is connected as above (on MGMT VLAN 99) via CRS310 and CCR2004, DL speed starts okay (~100MBps) and slowly drops to half or less (~45MBps).
I see from Wireshark capture that the data payload is about 1512 in size. When connected via CCR2004, I don’t see any cores reaching 100% during download test.
Am I missing something in my config that would explain poor WAN speed like this?
CCR2004 conf:
# 2024-06-11 10:18:58 by RouterOS 7.15.1
# software id =
# model = CCR2004-16G-2S+
# serial number =
add admin-mac=48:A9:8A:B3:EC:D8 auto-mac=no frame-types=\
admit-only-vlan-tagged name=RouterBridge priority=0x1000 vlan-filtering=\
yes
set [ find default-name=ether1 ] comment="FRACTAL IPMI"
set [ find default-name=ether2 ] comment="FRACTAL PROX MGMT"
set [ find default-name=ether3 ] comment="CRS310 MGMT" disabled=yes
set [ find default-name=ether4 ] comment="Jun Switch MGMT"
set [ find default-name=ether5 ] comment="Desktop Spare"
set [ find default-name=ether7 ] disabled=yes
set [ find default-name=ether8 ] disabled=yes
set [ find default-name=ether9 ] disabled=yes
set [ find default-name=ether10 ] disabled=yes
set [ find default-name=ether11 ] disabled=yes
set [ find default-name=ether12 ] disabled=yes
set [ find default-name=ether13 ] disabled=yes
set [ find default-name=ether14 ] disabled=yes
set [ find default-name=ether15 ] disabled=yes
set [ find default-name=sfp-sfpplus1 ] auto-negotiation=no comment=WAN speed=\
10G-baseT
set [ find default-name=sfp-sfpplus2 ] auto-negotiation=no comment=\
"CRS310 Switch"
/interface wireguard
add listen-port=13231 mtu=1280 name=homeGuard
/interface vlan
add interface=RouterBridge name=VLAN-10-CLIENT vlan-id=10
add interface=RouterBridge name=VLAN-20-WIFI vlan-id=20
add interface=RouterBridge name=VLAN-30-SERVER vlan-id=30
add interface=RouterBridge name=VLAN-40-DMZ vlan-id=40
add interface=RouterBridge name=VLAN-99-MGMT vlan-id=99
add name=WAN
add name=LAN
add name=MGMT
add name=DMZ
add name=SERVER
add include=DMZ,LAN,MGMT,SERVER name=Internal
add name=LANNoDMZ
add name=MGMT-POOL ranges=10.218.99.15-10.218.99.254
add name=CLIENT-POOL ranges=10.218.10.2-10.218.10.254
add name=WIFI-POOL ranges=10.218.20.2-10.218.20.254
add name=SERVER-POOL ranges=10.218.30.20-10.218.30.254
add name=DMZ-POOL ranges=10.218.40.2-10.218.40.254
add address-pool=CLIENT-POOL interface=VLAN-10-CLIENT lease-time=10m name=\
CLIENT-DHCP
add address-pool=WIFI-POOL interface=VLAN-20-WIFI lease-time=10m name=\
WIFI-DHCP
add address-pool=SERVER-POOL interface=VLAN-30-SERVER lease-time=10m name=\
SERVER-DHCP
add address-pool=DMZ-POOL interface=VLAN-40-DMZ lease-time=10m name=DMZ-DHCP
add address-pool=MGMT-POOL interface=VLAN-99-MGMT lease-time=10m name=\
MGMT-DHCP
/port
set 0 name=serial0
set 1 name=serial1
/queue interface
set sfp-sfpplus1 queue=multi-queue-ethernet-default
set sfp-sfpplus2 queue=multi-queue-ethernet-default
/routing pimsm instance
add disabled=yes name=pimsm-instance1 vrf=main
add bridge=RouterBridge frame-types=admit-only-vlan-tagged interface=\
sfp-sfpplus2
add bridge=RouterBridge frame-types=admit-only-untagged-and-priority-tagged \
interface=ether1 pvid=99
interface=ether2 pvid=99
interface=ether3 pvid=99
interface=ether4 pvid=99
interface=ether5 pvid=99
interface=ether6 pvid=99
add bridge=RouterBridge frame-types=admit-only-vlan-tagged interface=ether16
set udp-timeout=10s
/ipv6 settings
set disable-ipv6=yes
/interface bridge vlan
add bridge=RouterBridge tagged=RouterBridge,sfp-sfpplus2,ether16 vlan-ids=10
add bridge=RouterBridge tagged=RouterBridge,sfp-sfpplus2,ether16 untagged=\
ether1,ether2,ether3,ether4,ether5 vlan-ids=99
add bridge=RouterBridge tagged=RouterBridge,sfp-sfpplus2,ether16 vlan-ids=20
add bridge=RouterBridge tagged=RouterBridge,sfp-sfpplus2 vlan-ids=30
add bridge=RouterBridge tagged=RouterBridge,sfp-sfpplus2 vlan-ids=40
add interface=sfp-sfpplus1 list=WAN
add interface=VLAN-99-MGMT list=MGMT
add disabled=yes interface=ether2 list=MGMT
add disabled=yes interface=ether3 list=MGMT
add disabled=yes interface=ether4 list=MGMT
add disabled=yes interface=ether5 list=MGMT
add interface=VLAN-10-CLIENT list=LAN
add interface=VLAN-20-WIFI list=LAN
add interface=VLAN-30-SERVER list=SERVER
add interface=VLAN-40-DMZ list=DMZ
add interface=homeGuard list=Internal
add interface=VLAN-10-CLIENT list=LANNoDMZ
add interface=VLAN-20-WIFI list=LANNoDMZ
add interface=VLAN-30-SERVER list=LANNoDMZ
add interface=VLAN-99-MGMT list=LANNoDMZ
add interface=RouterBridge list=LAN
/interface wireguard peers
add allowed-address=10.219.0.4/32 comment=IPAD interface=homeGuard name=peer3 \
add allowed-address=10.219.0.5/32 comment=MACBOOK interface=homeGuard name=\
add allowed-address=10.219.0.3/32 interface=homeGuard name=peer2 public-key=\
add address=192.168.88.1/24 comment=defconf disabled=yes interface=ether15 \
network=192.168.88.0
add address=10.218.10.1/24 interface=VLAN-10-CLIENT network=10.218.10.0
add address=10.218.20.1/24 interface=VLAN-20-WIFI network=10.218.20.0
add address=10.218.30.1/24 interface=VLAN-30-SERVER network=10.218.30.0
add address=10.218.40.1/24 interface=VLAN-40-DMZ network=10.218.40.0
add address=10.218.99.1/24 interface=VLAN-99-MGMT network=10.218.99.0
add address=10.219.0.1/24 interface=homeGuard network=10.219.0.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
/ip dhcp-server lease
add address=10.218.10.0/24 gateway=10.218.10.1
add address=10.218.20.0/24 gateway=10.218.20.1
add address=10.218.30.0/24 gateway=10.218.30.1
add address=10.218.40.0/24 gateway=10.218.40.1
add address=10.218.99.0/24 gateway=10.218.99.1
set allow-remote-requests=yes
add action=accept chain=input comment="Accept established, related" \
add action=drop chain=input comment="Drop invalid input" connection-state=\
invalid
add action=accept chain=input comment="Accept ICMP" protocol=icmp
add action=accept chain=input comment="Allow WireGuard from WAN" dst-port=\
13231 protocol=udp
add action=accept chain=input comment="Allow WireGuard Input" in-interface=\
homeGuard src-address=10.219.0.0/24
add action=accept chain=input comment="Allow input from MGMT" \
in-interface-list=MGMT
add action=accept chain=input comment="Allow MacBook to MGMT" in-interface=\
VLAN-20-WIFI src-address=10.218.20.5
add action=accept chain=input comment="Allow iPhone to MGMT" in-interface=\
VLAN-20-WIFI src-address=10.218.20.6
add action=accept chain=input comment="Allow DNS from all internal" dst-port=\
53 in-interface-list=Internal protocol=udp
53 in-interface-list=Internal protocol=tcp
add action=drop chain=input comment="Drop all other Input"
add action=fasttrack-connection chain=forward comment="FAST TRACK FORWARD" \
add action=accept chain=forward comment="Forward Established and Tracked" \
add action=drop chain=forward comment="Drop invalid forward" \
connection-state=invalid
add action=accept chain=forward comment="Allow internal clients to internet" \
connection-state=new in-interface-list=Internal out-interface-list=WAN
add action=accept chain=forward comment="Allow MGMT to ALL Internal" \
in-interface-list=MGMT out-interface-list=Internal
add action=accept chain=forward comment="PLEX Forward to DMZ" dst-port=32400 \
in-interface=sfp-sfpplus1 protocol=tcp
add action=accept chain=forward comment="Allow DMZ Docker to access NFS" \
dst-address=10.218.30.5 in-interface=VLAN-40-DMZ src-address=10.218.40.3
add action=accept chain=forward comment="Allow Internal Clients to Plex DMZ" \
dst-address=10.218.40.3 in-interface-list=LANNoDMZ
add action=accept chain=forward comment="WireGuard to LAN" in-interface=\
homeGuard out-interface-list=Internal
homeGuard out-interface-list=WAN
connection-nat-state=!dstnat connection-state=new in-interface=\
sfp-sfpplus1
add action=drop chain=forward comment="Drop All Other Forward"
add action=dst-nat chain=dstnat dst-port=32400 in-interface=sfp-sfpplus1 \
protocol=tcp to-addresses=10.218.40.3 to-ports=32400
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set h323 disabled=yes
set sip disabled=yes
/ip service
set telnet disabled=yes
set www disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=America/Denver
/system note
set show-at-login=no
/system routerboard settings
set enter-setup-on=delete-key
/tool bandwidth-server
set enabled=no
/tool mac-server
set allowed-interface-list=MGMT
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
CRS310 conf:
# 2024-06-11 10:20:43 by RouterOS 7.15
# software id =
# model = CRS310-1G-5S-4S+
# serial number =
add admin-mac=18:FD:74:6A:F2:E7 auto-mac=no comment=defconf name=bridge \
vlan-filtering=yes
set [ find default-name=sfp-sfpplus1 ] comment=DESKTOP
set [ find default-name=sfp-sfpplus3 ] comment="SERVER FRACTAL"
set [ find default-name=sfp-sfpplus4 ] comment="CCR2004 RTR UPLINK"
/interface vlan
add interface=bridge name=vlan-99-mgmt vlan-id=99
/port
set 0 name=serial0
/queue interface
set sfp-sfpplus3 queue=multi-queue-ethernet-default
add bridge=bridge comment=defconf frame-types=\
admit-only-untagged-and-priority-tagged interface=sfp-sfpplus1 pvid=99
add bridge=bridge comment=defconf interface=sfp-sfpplus2
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged \
interface=sfp-sfpplus3
add bridge=bridge comment=defconf interface=sfp-sfpplus4
admit-only-untagged-and-priority-tagged interface=sfp1 pvid=10
add bridge=bridge comment=defconf interface=sfp2
add bridge=bridge comment=defconf interface=sfp3
add bridge=bridge comment=defconf interface=sfp4
add bridge=bridge comment=defconf interface=sfp5
add bridge=bridge tagged=sfp-sfpplus4 untagged=sfp1,sfp2,sfp3,sfp4 vlan-ids=\
10
add bridge=bridge tagged=sfp-sfpplus4,bridge untagged=sfp-sfpplus1,ether1 \
vlan-ids=99
add bridge=bridge tagged=sfp-sfpplus3,sfp-sfpplus4 vlan-ids=30
add bridge=bridge tagged=sfp-sfpplus3,sfp-sfpplus4 vlan-ids=40
add address=192.168.88.1/24 comment=defconf disabled=yes interface=bridge \
add address=10.218.99.2/24 interface=vlan-99-mgmt network=10.218.99.0
set servers=8.8.8.8
/ip hotspot profile
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=10.218.99.1 \
routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/system clock
/system note
set boot-os=router-os
