Slow Wifi Speeds On RB4011iGS+5HacQ2HnD
I have been using the Mikrotik routers since 2017 my first being a RB750Gr3 and now I have a RB4011iGS+5HacQ2HnD. I have an ISP 1 Gbps Fiber to the Home internet connection which is shared however when I am hard wired to the router I get 500 Mbps Up and 700 Mbps download which is understood and acceptable. On the flip side when I am connected wirelessly to the Wifi Router I get very poor speeds of 120 Mbps and lower. See setup of router below. Any help in identifying a likely misconfiguration or how to get speeds of 500 Mbps using Wifi would be greatly appreciated.
add name=BR1 protocol-mode=none vlan-filtering=yes
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n/ac country=“united states”
disabled=no frequency=5825 installation=indoor mode=ap-bridge ssid=
********* wireless-protocol=802.11
set [ find default-name=wlan2 ] band=2ghz-b/g/n country=“united states”
disabled=no frequency=2462 mode=ap-bridge ssid=************
set [ find default-name=sfp-sfpplus1 ] advertise=1000M-full
/interface vlan
add interface=BR1 name=BASE_VLAN vlan-id=99
add interface=BR1 name=BLUE_VLAN vlan-id=10
add interface=BR1 name=GREEN_VLAN vlan-id=20
set 0 default-vlan-id=10
set 1 default-vlan-id=10
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 4 default-vlan-id=0
set 5 default-vlan-id=0
set 6 default-vlan-id=0
set 7 default-vlan-id=0
set 8 default-vlan-id=0
set 9 default-vlan-id=0
set 10 default-vlan-id=0
set 11 default-vlan-id=0
add name=WAN
add name=VLAN
add name=BASE
add name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk group-ciphers=
tkip,aes-ccm mode=dynamic-keys supplicant-identity=MikroTik
unicast-ciphers=tkip,aes-ccm wpa-pre-shared-key=3475819507
wpa2-pre-shared-key=3475819507
add authentication-types=wpa2-psk mode=dynamic-keys name=guest2
supplicant-identity=MikroTik wpa2-pre-shared-key=7726216175
add authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys name=Base
supplicant-identity=MikroTik wpa-pre-shared-key=7726216175
/interface wireless
add disabled=no mac-address=76:4D:28:8C:55:1D master-interface=wlan1 name=
wlan3 security-profile=guest ssid=****** vlan-id=10
add disabled=no mac-address=76:4D:28:02:82:15 master-interface=wlan2 name=
wlan4 security-profile=guest2 ssid=*t vlan-id=20
add disabled=no mac-address=76:4D:28:8C:55:1E master-interface=wlan1 name=
wlan5 security-profile=Base ssid=
vlan-id=10
add name=BLUE_POOL ranges=10.0.10.2-10.0.10.254
add name=GREEN_POOL ranges=10.0.20.2-10.0.20.254
add name=BASE_POOL ranges=192.168.100.10-192.168.100.254
add address-pool=BLUE_POOL disabled=no interface=BLUE_VLAN name=BLUE_DHCP
add address-pool=GREEN_POOL disabled=no interface=GREEN_VLAN name=GREEN_DHCP
add address-pool=BASE_POOL disabled=no interface=BASE_VLAN name=BASE_DHCP
add bridge=BR1 frame-types=admit-only-untagged-and-priority-tagged
ingress-filtering=yes interface=ether1 pvid=10
ingress-filtering=yes interface=ether2 pvid=10
ingress-filtering=yes interface=ether3 pvid=10
ingress-filtering=yes interface=ether4 pvid=10
ingress-filtering=yes interface=wlan1 pvid=10
ingress-filtering=yes interface=wlan3 pvid=10
ingress-filtering=yes interface=ether5 pvid=20
add bridge=BR1 interface=ether6 pvid=20
ingress-filtering=yes interface=wlan2 pvid=20
ingress-filtering=yes interface=wlan4 pvid=20
ingress-filtering=yes interface=wlan5 pvid=99
set discover-interface-list=BASE
/interface bridge vlan
add bridge=BR1 tagged=BR1 untagged=
ether1,ether2,ether3,ether4,wlan1,wlan3,wlan5 vlan-ids=10
add bridge=BR1 tagged=BR1 untagged=ether5,ether6,wlan2,wlan4 vlan-ids=20
add bridge=BR1 tagged=BR1 untagged=wlan5 vlan-ids=99
add interface=BASE_VLAN list=VLAN
add interface=BLUE_VLAN list=VLAN
add interface=GREEN_VLAN list=VLAN
add comment=“For Management - Connecting To Winbox” interface=BASE_VLAN list=
BASE
add interface=ether1 list=LAN
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=ether5 list=LAN
add interface=ether6 list=LAN
add interface=ether7 list=LAN
add interface=ether8 list=LAN
add interface=ether9 list=LAN
add interface=ether10 list=LAN
add interface=wlan2 list=LAN
add interface=sfp-sfpplus1 list=WAN
add interface=BR1 list=LAN
add address=192.168.100.1/24 interface=BASE_VLAN network=192.168.100.0
add address=75.4.211.120/23 interface=sfp-sfpplus1 network=75.4.210.0
add address=10.0.10.1/24 interface=BLUE_VLAN network=10.0.10.0
add address=10.0.20.1/24 interface=GREEN_VLAN network=10.0.20.0
add address=192.168.200.10/24 interface=BR1 network=192.168.200.0
add address=10.0.10.0/24 dns-server=192.168.200.10 gateway=10.0.10.1
add address=10.0.20.0/24 dns-server=192.168.200.10 gateway=10.0.20.1
add address=192.168.100.0/24 dns-server=192.168.200.10 gateway=192.168.100.1
set allow-remote-requests=yes servers=1.1.1.1,192.168.200.10
add action=accept chain=input comment=“Allow Estab & Related”
add action=accept chain=input comment=“Allow VLAN” in-interface-list=VLAN
add action=accept chain=input comment=“Allow Base_Vlan Full Access”
in-interface=BASE_VLAN
add action=drop chain=input comment=Drop
add action=accept chain=forward comment=“Allow Estab & Related”
add action=accept chain=forward comment=“VLAN Internet Access only”
connection-state=new in-interface-list=VLAN out-interface-list=WAN
add action=drop chain=forward comment=Drop
add action=accept chain=forward connection-state=established,related
add action=masquerade chain=srcnat comment=“Default masquerade”
add distance=1 gateway=75.4.210.1
add check-gateway=arp distance=2 dst-address=192.168.1.0/24 gateway=
192.168.1.254
/ip service
set ssh port=59222
set winbox port=58291
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=BR1 type=internal
add interface=sfp-sfpplus1 type=external
/system clock
set time-zone-name=America/New_York
/system identity
set name=RouterSwitchAP
/system leds
add interface=wlan2 leds=“wlan2_signal1-led,wlan2_signal2-led,wlan2_signal3-le
d,wlan2_signal4-led,wlan2_signal5-led” type=wireless-signal-strength
add interface=wlan2 leds=wlan2_tx-led type=interface-transmit
add interface=wlan2 leds=wlan2_rx-led type=interface-receive
/tool mac-server
set allowed-interface-list=BASE
/tool mac-server mac-winbox
RouterOS.
Pick another vendor for wireless.
Cambium XV2-2 WiFi6 WAP connected to my hAP AC2.
MT 5GHz UDP data throughput is 260Mbps for 40MHz/2S/SGI and only 360Mbps for 80MHz/2S/SGI.
TCP may be slower due to TCP congestion avoidance, and some wifi glitches in the 6.48+ ROS versions.
500 Mbps only with ROS7 and wifiwave2 drivers
Hint: avoid WPA and certainly TKIP in wifi security.
Unfortunately I live in a HOA so I have no option of choosing another ISP. After tweaking the frequency setting for the 5 GHz I was able to get 150 on the Wireless when connected on the wireless and when hard wired to the router I get 400 Mbps. I post my configuration for that change shortly.
Put your wireless access point of choice ontop of the RB4011, and turn off the Mikrotik wireless.
Any suggestions ?
