Slow wireless on Mikrokit HAP Lite
I just got a HAP Lite and plugged it in, changed the admin password and the wifi password. My download speeds topped off at 15mbps on wifi, while I was getting 60mbps wired. It’s my first experience with RouterOS so I’m unaware if any initial configuration is required for best performance. I was unable to find how to export logs to post. Can someone offer any guidance? Thanks
The speed you can get is up to the client and the noise (interference) in the area. However, try this and report back.
Interfaces / wlan1 / Wireless tab:
  • Mode: ap bridge
    Band: 2Ghz-B/G/N
    Channel Width: 20/40Mhz eC
    Freguency: 2437
    WPS Mode: disabled
    Frequency Mode: regulatory-domain
Interfaces / wlan1 / HT tab:
  • check all Tx and Rx Chains
