I have three ccr1072s. two are in production and the other is connected to one of the production units via a 10G fiber. I have a 2gig uplink from the production router. The issue I have is I cannot get over about 500mbps when I run a speedtest at speedtest.net.
Let me give a little background to understand my situation. I work for a small wisp and we have fiber in a building. There are other tenants in this building and we would like to sell gig service, but have been unable at this point due to this problem. We currently have two fiber providers for uplinks and each has a ccr1072 connected to it. We utilize vrrp as a failover for our service.
in order to test the system, I set up the third ccr1072(spare) on a workbench and ran a fiber between it and one of the production units. I ran a bandwidth test between the units and get 9 Gbps using UDP but only 500 Mbps using TCP. I am unable to figure out why I have this limitation. Neither router gets anywhere close to maxing the CPU.
I would appreciate any ideas or thoughts.
Thanks,
Adding the config now. Sorry I did not post that immediately. This is the production unit. The other unit has only an ip address, dns and nat rule. I will upload that as well here shortly.
Removing everything for now. I was in too much of a hurry and may have posted too much.
