Hello gurus
I have the following situation which bugs my brain.
I have a UK Vodafone fiber to the home setup (from ONT to VF router) which I have taken the PPPoe username/password and VLAN id into my Mikrotik.
When I am connected o the Vodafone router, I get 530Mbps download and 574.5 Mpbs upload while speed testing.
When I am connected to the Mikrotik, I get 512Mpbs download and 217Mbps upload.
I have checked that the frequencies do not overlap and even went to the extend of switching OFF and Mikrotik and test VF. Then switch OFF the VF and test the Mikrotik.
All tests are done back to back within few minutes of difference.
Is there anything I am missing?
MT_model: C53UiG+5HPaxD2HPaxD
MT_firmware: 7.11
# 2025-02-08 10:37:05 by RouterOS 7.11
# software id = ZADD-MHDI
# model = C53UiG+5HPaxD2HPaxD
# serial number = xxxxxxxxxx
add admin-mac=xx:xx:xx:xx:xx:xx auto-mac=no comment=defconf name=bridge
/interface vlan
add interface=ether1 mtu=xxx name=vlan1-xxx vlan-id=xxx
/interface pppoe-client
add add-default-route=yes disabled=no interface=xxx name=\
pppoe-out1 use-peer-dns=yes user=xxxusernamexxx
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wifiwave2 security
add authentication-types=wpa2-psk,wpa3-psk disabled=no encryption="" name=\
xxx-SEC
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac \
configuration.country="United Kingdom" .mode=ap .ssid=xxx-5G \
disabled=no name=wifi1-5G security=xxx-SEC \
security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac \
configuration.country="United Kingdom" .mode=ap .ssid=xxx-2.4G \
disabled=no name=wifi2-2.4G security=xxx-SEC \
add name=default-dhcp ranges=xxx.xxx.xxx.xx-xxx.xxx.xx.xxx
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
add bridge=bridge comment=defconf interface=wifi1-5G
add bridge=bridge comment=defconf interface=wifi2-2.4G
add interface=*9 list=WAN
add address=xxx.xxx.xx.x/xx comment=defconf interface=bridge network=\
xxx.xxx.xx.x
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
add address=xxx.xxx.xx.x/xx comment=defconf dns-server=192.168.88.1 gateway=\
xxx.xxx.xx.x
set allow-remote-requests=yes
/ip dns static
add address=xxx.xxx.xx.x comment=defconf name=router.lan
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
