Sluggish web browsing via Wireguard on Mikrotik
Hi All,
I’m experiencing sluggish web browsing when using a WireGuard connection to AirVPN through my Mikrotik router.
My home internet connection is 1Gbps download / 50Mbps upload.
Router is a Mikrotik hAP ac RB962UiGS (firmware version 7.16)
When I use the Eddie client on my phone or PC to connect to the WireGuard server in Singapore, web browsing is fast and responsive.
Eddie is AirVPNs client application, it’s configured to use Wireguard and connect to the same server.
However, when I configure WireGuard directly on the Mikrotik hAP to connect to the same server and route my PC or phone traffic through the tunnel, browsing slows down significantly—almost to the point of being unusable.
Everything connects successfully, but the degraded browsing performance is a disappointing.
It doesn’t appear to be resources on the Mikrotik, when attempting to download a file of the Mikrotik wireguard tunnel, CPU barely gets to 20%
Can anyone give guidance on how to improve the performance?
Am I doing something wrong?
Should I use another method for the routing part? ie routing rules instead of NAT mangle?
Here is my Mikrotik Config..
WAN is ether1
LAN is ether2
WG is wg-airvpn
# by RouterOS 7.16
# software id = ITU9-GZKB
# model = RB962UiGS-5HacT2HnT
set [ find default-name=ether3 ] disabled=yes
set [ find default-name=ether4 ] disabled=yes
set [ find default-name=ether5 ] disabled=yes
set [ find default-name=sfp1 ] disabled=yes
/interface wireguard
add listen-port=13231 mtu=1320 name=wg-airvpn
add name=LAN
add name=WAN
/interface lte apn
/routing table
add disabled=no fib name=wireguard
set udp-timeout=10s
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
add interface=ether2 list=LAN
add interface=ether1 list=WAN
/interface ovpn-server server
set auth=sha1,md5
/interface wireguard peers
add allowed-address=0.0.0.0/0 endpoint-address=sg3.vpn.airdns.org endpoint-port=1637 interface=wg-airvpn name=peer2 persistent-keepalive=15s preshared-key="XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX" public-key="XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"
add address=10.152.XXX.XXX interface=wg-airvpn network=10.152.XXX.XXX
add address=172.28.28.1/28 interface=ether2 network=172.28.28.0
/ip cloud
set update-time=no
/ip dhcp-client
/ip firewall address-list
add address=172.28.30.199 list="VPN Only"   # My PC
add action=accept chain=input comment="accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=input comment="drop invalid" connection-state=invalid
add action=accept chain=input comment="accept ICMP" in-interface=ether1 protocol=icmp
add action=drop chain=input comment="block everything else" in-interface=!ether2
add action=fasttrack-connection chain=forward comment="fast-track for established,related" connection-state=established,related hw-offload=yes
add action=accept chain=forward comment="accept established,related" connection-state=established,related
add action=drop chain=forward comment="drop invalid" connection-state=invalid
add action=reject chain=forward comment="reject WAN access to VPN Only List"  out-interface=ether1 reject-with=icmp-network-unreachable src-address-list="VPN Only"
add action=drop chain=forward comment="drop access to clients behind NAT from WAN" connection-nat-state=!dstnat connection-state=new in-interface=!ether2 log=yes
/ip firewall mangle
add action=mark-routing chain=prerouting dst-address=!172.28.28.0/22 new-routing-mark=wireguard passthrough=yes src-address-list="VPN Only"
add action=change-mss chain=forward new-mss=clamp-to-pmtu out-interface=wg-airvpn passthrough=yes protocol=tcp tcp-flags=syn
add action=masquerade chain=srcnat out-interface=wg-airvpn
/ip ipsec profile
add disabled=no dst-address=10.128.0.1/32 gateway=wg-airvpn routing-table=main suppress-hw-offload=no
add disabled=no distance=1 dst-address=172.28.28.0/22 gateway=172.28.28.14 routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add disabled=no dst-address=8.8.4.4/32 gateway=wg-airvpn routing-table=main suppress-hw-offload=no
add disabled=no dst-address=0.0.0.0/0 gateway=wg-airvpn routing-table=wireguard suppress-hw-offload=no
/ip service
set telnet address=172.28.28.0/22 disabled=yes
set ftp address=172.28.28.0/22 disabled=yes
set www address=172.28.28.0/22
set ssh address=172.28.28.0/22
set www-ssl address=172.28.28.0/22
set api address=172.28.28.0/22
set winbox address=172.28.28.0/22
set api-ssl address=172.28.28.0/22 disabled=yes
/ip ssh
set strong-crypto=yes
/routing bfd configuration
add disabled=no interfaces=all min-rx=200ms min-tx=200ms multiplier=5
/routing rule
add action=lookup-only-in-table disabled=yes src-address=172.28.29.128/25 table=wireguard
/system clock
set time-zone-name=Australia/Sydney
/system identity
set name=bump
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=pool.ntp.org
/tool bandwidth-server
set enabled=no
/tool graphing interface
add
/tool graphing queue
add
/tool graphing resource
add
/tool mac-server
/tool mac-server mac-winbox
My thought is to disable the fasttrack rule and see if that helps.
Fast tracked traffic does not get packet/routing marks applied.
If it helps, you might be better off with routing rules.
As they should continue to work with/without fasttrack.
Well, I disabled my mangle rule and enabled my routing rule.
Instant massive improvement!
I’m not sure why that didn’t work for me when I tried it last time..
/ip firewall mangle
add action=mark-routing chain=prerouting disabled=yes dst-address=!172.28.28.0/22 new-routing-mark=wireguard passthrough=yes src-address-list="VPN Only"
/routing rule
add action=lookup-only-in-table disabled=no src-address=172.28.30.199/32 table=wireguard
