clear counters on /int OR make the columns wider?
We pull queue stats with /queue simple print stats file=stats
at midnight for bandwidth mgt, and also started running
/interface print stats file=ether to compare total bandwidth on our backbone ether port
Unfortunately, after a few days the stats on /int are too large of numbers and get truncated
"2575841162300/10563542… "
(I’m using 3.28 and haven’t loaded 4. beta yet. I’m assuming this part is the same)
