I am in the process of converting all of my old smartbridges Access points over to MT based access points using Super range radios. All is well, getting great throughput on the access points and mt clients. However, I have a lot of smartbridges clients deployed and it seems that they will only associate with version 2.9.8 or earlier versions of the mt software. The only error I get from the smartbridges is about check WEP settings. The mikrotik ap doesn’t flag any error whatsoever. If I sniff the wireless link, I can see traffic from the smartbridge client, but in terms of associating, it appears to completely ignore it. If I try this with 2.9.8 it associates immediately. I have also tried with 2.9.7 and it also works flawlessly. I’d like to be able to continue to use newer versions of Mikrotik as they become available. Has anyone else seen this issue?
In lieu of a solution, does anyone have the complete 2.9.8 software available? If I have to, I’ll just downgrade the effected access points until I can find another solution.
Craig Russell
