SmartThings and SharkClean Notifications Stopped Working
Hello, very new user of MikroTik hEX S Gigabit router.. Been in IT 20 years but not heavy on network side.. Got this router so I can enable Netflow and monitor traffic.. Still playing with that to get it working..
That being said, one thing I noticed that broke after I installed this router are my notifications from Samsung SmartThings and my SharkClean vacuum robot.. Any ideas what logs I can look through to see what broke (or how to fix)?
Not enough info.
Network diagram (should show devices and subnets)
config
What notices were you getting before? Do you mean on PC? on Smartphone?
Network diagram is pretty simple.. Just have ISP Cable Modem plugged into MikroTik and a few unmanaged switches and Eero Mesh system.. Everything is on same subnet/vlan..
Thanks for the reply.. Yes, I would get notices on my iPhone.. IE: When my garage door opened, SmartThings would send me an alert.. When my Shark Vacuum got stuck, the app would send me a notification. Both stopped working when I installed the MikroTik
# oct/15/2021 09:31:22 by RouterOS 6.49
# software id = 0D08-KEW9
# model = RB760iGS
# serial number = E2080E6C8152
add admin-mac=2C:C8:1B:90:9B:0B auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] name=Armstrong
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=default-dhcp ranges=192.168.7.200-192.168.7.250
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
/dude
set enabled=yes
add bridge=bridge comment=defconf interface=sfp1
set discover-interface-list=!all
/interface detect-internet
set detect-interface-list=all
add comment=defconf interface=Armstrong list=WAN
add address=192.168.7.1/24 comment=defconf interface=bridge network=192.168.7.0
/ip dhcp-client
add comment=defconf disabled=no interface=Armstrong
/ip dhcp-server lease
add address=192.168.7.240 client-id=1:14:2f:fd:8:81:c3 mac-address=14:2F:FD:08:81:C3 server=defconf
add address=192.168.7.232 mac-address=4C:01:43:1D:F3:EB server=defconf
add address=192.168.7.233 mac-address=4C:01:43:1E:4B:2B server=defconf
add address=192.168.7.228 client-id=1:74:da:38:68:dc:6f mac-address=74:DA:38:68:DC:6F server=defconf
add address=192.168.7.226 mac-address=4C:01:43:9B:7F:02 server=defconf
add address=192.168.7.246 client-id=1:14:4f:8a:bf:61:39 mac-address=14:4F:8A:BF:61:39 server=defconf
add address=192.168.7.242 client-id=1:c2:b6:ce:ff:54:13 mac-address=C2:B6:CE:FF:54:13 server=defconf
add address=192.168.7.229 client-id=1:d2:33:7c:35:d9:e7 mac-address=D2:33:7C:35:D9:E7 server=defconf
add address=192.168.7.216 client-id=1:18:c8:e7:34:89:e2 mac-address=18:C8:E7:34:89:E2 server=defconf
add address=192.168.7.0/24 comment=defconf gateway=192.168.7.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.7.1 comment=defconf name=router.lan
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip kid-control device
add mac-address=F0:D1:A9:21:5F:92 name=Calebs-iPad
/ip traffic-flow
set enabled=yes
/ip traffic-flow target
add dst-address=192.168.7.26 port=9996
/snmp
set enabled=yes
/system clock
set time-zone-name=America/New_York
/tool graphing interface
add
/tool mac-server
/tool mac-server mac-winbox
yeah that is weird, if everything is on the same subnet.
What is aeromesh??
Just a mesh wifi solution - https://eero.com
So the aero mesh worked with the previous router with no issues??
Connected to the Router via wired connection (I guess at least one of them)?
Yup, the Eero system is in bridge mode so it connects to the wifi and then gets DHCP from the Mikro. It all worked fine with the other router.. And yes, the main Eero is hard wired to the Mikro and then there are two extenders that are wireless that connect to the main..
So the euromesh gets its IP address from the MT??
Yes, everything does..
Do the notifications like all of my devices, go from device to device manufacturer cloud servers, and then to my smartphone ??
All your devices have internet access and thus you should get notices on your smartphone?
Yes.. I just logged into the Samsung SmartThings UI and it says the hub is online etc so it is talking to the cloud.. Actually, when it’s offline nothing works (light control, etc)..
Try changing this
TO
Also
Try deleting the static DNS setting of 192.168.7.1
/ip dns static
and adding under servers 1.1.1.1 and 9.9.9.9 to see if that makes any difference
Lastly the smart things server, did it get its IP from the router or did you set it manually and is it now a static IP.
