SMD repair part needed DynaDish G 5HacD
Hi, I have two DynaDish G 5HacD with power supply flashing, a shorticut in the power line of the board, I find this IC (I think a voltage regulator for multiple outputs voltages) that it´s in short… It´s marked in the board as U100
Any knows where I can buy it or where is the commercial reference?
In the body say something like “6b ti 5460” or “6b t1 5460”
Thanks!!
It is TI 54**1**60, AKA TPS54160, aka TPS54160DGQ:
https://www.ti.com/product/TPS54160
it is a fairly common voltage regulator/converter.
The 6B is irrelevant, it is the production date code, seems 2006-November (or maybe 2016-November?)
You can find them on professional sources like RS, Digikey or Mouser or test your luck on Aliexpress or Amazon/ebay, they are ubiquitous.
Oh great, yes, you´re right, it was the reference, I lost the “one”
Thanks a lot for your help!!
