Good morning,
I have been trying to set up a hotspot service on a hAP LITE, but have been having issues with the walled garden. It seems like traffic to any domains that i place in the walled garden still gets rejected. I also do not see any of the counters increasing when i try to visit a domain in the whitelist.
I can get to places if i add the ip of a server in the “walled garden ip list” but that is it.
I have run the same script on another device *hAP AC lite" running a mipsbe firmware… and it work just fine there… both devices only had factory default settings before the script was run.
Config:
# Set the interface name to use with hotspot
# Examples:
# :global hotspotinterface ether2
# :global hotspotinterface wlan1
# :global hotspotinterface bridge1
# Configure the NasID (from Control Panel)
:global nasid deviceid
# for temp management
/ip firewall filter add action=accept in-interface=ether1 protocol=tcp dst-port=8291 place-before=1 chain=input
/ip firewall filter add action=accept in-interface=ether1 protocol=tcp dst-port=22 place-before=2 chain=input
/ip hotspot
add disabled=no name=[/interface ethernet get [/interface ethernet find default-name="ether1"] mac-address] interface="$hotspotinterface"
/ip hotspot profile
set [ find default=yes ] login-by=http-chap use-radius=yes
/ip hotspot user profile
set [ find default=yes ] add-mac-cookie=no
/ip hotspot walled-garden
add dst-host=*mywifi.io
add dst-host=*guestlinx.com
add dst-host=*securewifilogin.com
add dst-host=*cloudfront.net
add dst-host=*fonts.gstatic.com
add dst-host=*fonts.googleapis.com
add dst-host=*linkedin.com
add dst-host=*amazonaws.com
add dst-host=*licdn.com
add dst-host=*twitter.com
add dst-host=*facebook.com
add dst-host=*fbcdn.net
add dst-host=*akadns.net
add dst-host=*edgekey.net
add dst-host=*edgesuite.net
add dst-host=*akamaihd.net
add dst-host=*akamaiedge.net
add dst-host=*akamai.net
add dst-host=*twimg.com
add dst-host=*instagram.com
add dst-host=*facebook.net
add dst-host=*stripe.com
add dst-host=*paypal.com
add dst-host=*paypalobjects.com
add dst-host=*twilio.com
add dst-host=*vk.com
add dst-host=*js.authorize.net
/ip hotspot walled-garden ip
add action=accept disabled=no dst-host=js.stripe.com
add action=accept disabled=no dst-host=js.authorize.net
/radius
add address=IP1 disabled=no secret=mywifi service=hotspot
add address=IP2 disabled=no secret=mywifi service=hotspot
/system identity
set name="$nasid"
:delay 3s
:global hotspotdirectory [/ip hotspot profile get [find] html-directory]
/file remove [/file find name="$hotspotdirectory/login.html"]
/file remove [/file find name="$hotspotdirectory/rlogin.html"]
/file remove [/file find name="$hotspotdirectory/alogin.html"]
/file remove [/file find name="$hotspotdirectory/lv"]
/file remove [/file find name="$hotspotdirectory/img"]
/file remove [/file find name="$hotspotdirectory/xml"]
