SMS again - GSM via COM port
Hi All,
First post - love The Dude!
We need to send SMS messages out via a GSM modem connected to a PC running The Dude 3.6. As far as I can tell SMS hasn’t yet been added to a more recent release.
Our modem provides SMS sending capability via the AT command set (at+cmgs) on a COM port.
I’m comfortable with the execute locally notification, batch files and calling putty sessions. I can easily create a text file of AT commands to send the required SMS including a trailing Ctrl-Z but I can’t imagine how to close the COM port putty session once the sms has been sent.
I’ve seen Morphology’s VB6 source code post but compiling it is beyond me.
I’ve seen gsandul’s reply on another subject which happens to mention smsadmin.js - if you’re watching can I see the script?
I found mention of this functionality in RouterOS, but not The Dude.
Otherwise I’m looking for a utility that can interact with a serial port AT command line using at+cmgs and close the port once the modem replies OK.
I had a quick look around but the scripts I found all seem to use http SMS gateways, which isn’t applicable.
Any suggestions on a suitable utility or other mechanism to send SMS are most welcome.
Thanks in advance,
I use smsadmin.js to post messages through WEB interface of our SMPP server. This will not help you.
Good for you. It means you can use smstools3 to send your messages. You can compile it under Windows using cygwin. It realy works.
http://smstools3.kekekasvi.com/index.php?p=windows
Below is link to Microsoft SMS Sender utility:
http://www.microsoft.com/downloads/en/details.aspx?FamilyID=06a4f997-7f69-4891-8929-37b9041924a2&displaylang=en
I don’t know how it works with COM-connected modems, I used mobile phone to sent SMS.
Give it a try, it’s well documented and can be easily scripted to suite your needs.
Some time ago I used it for massive SMS sending and worked perfectly.
HTH,
Thanks for the replies. Neither smstools nor Microsoft’s utility worked for me due to the modem itself.
Smstools is nicely configurable and was looking good but it works only in PDU mode and the device does not support this.
The MS utility requires that a modem driver be installed and this is not available either.
The modem manufacturer is interested but we don’t know the timeframe for their solution.
If anyone has seen a simple text based sms sender I’d be pleased to hear it
Have you Tried using Echo?
sendsms.cmd
echo AT+CMGS=“+phonenumber” > com3
echo Your ‘OMG the sky is falling’ SMS message here (Ctrl-Z) > com3
Use notepad++ to create the CRLF and CTRL-Z or you can send using two echo statements. Pass variables by declairing and setting an environment variable.
Works with a Verizon MiFi puck on windows XP.
