Something is wrong if you’re needing to do a AT+CPIN, that should be correctly handled by RouterOS. And if not the logs would very likely show an issue. So a script that scan the logs is what may be best, dunno. /tool/watchdog with a ping can also solve the last line of defense, no ping after X minutes, reboot – covers other things than LTE but dirt simple fail-safe
I do have some generic AT parsing code to at least wraps “at-chat” looking for OK, or “throwing” an :error. The $ATVAR is function wraps “at-chat” and returns just the result as a string. $AT will do same but output (:put) the result.
:global ATVAR
:set ATVAR do={
:local checkok 1;
:local atchatwait "yes";
:local cmd [:tostr $1]
:put $cmd
:local r [/interface/lte/at-chat [find running] input="$cmd" wait=$atchatwait as-value];
:set r ($r->"output");
if (checkok>0) do={
:local s [:find $r "OK"];
:if (s>0) do={
:local z [:pick $r 0 $s];
:return [:tostr $z];
} else={:error "ATVAR got error: $r"}
} else={:return $r}
:global AT
:set AT do={
:global ATVAR;
:local z [$ATVAR $1];
:put $z;
:return $z;
I also do have one that parses the Telit LM960s AT#RFSTS, to get the actual tower info eNB need for cellmapper. But as you can see parsing these is complex and specific to the command. e.g. the AT#RFSTS can return 15, 16, or 17 items depending on the band/connection/etc. Maybe it helps.
:global toarrayFromTelitResponse
:set toarrayFromTelitResponse do={
:local z [ [:tostr [:pick $1 ([:find $1 ":"]+2) [:len $1] ]]]
:return [:toarray $z];
:global toarrayApplyTemplate
:set toarrayApplyTemplate do={
:local s [toarray "$2"];
:local z [:toarray ""];
:foreach i,k in=$s do={:set ($z->$k) ($1->$i)};
:log debug message="toarrayApplyTemplate $s -> $z";
:return $z;
:global ATrfsts
:set ATrfsts do={
:global toarrayApplyTemplate;
:global toarrayFromTelitResponse;
:global ATVAR;
:local TErfsts1 "PLMN,EARFCN,RSRP,RSSI,RSRQ,TAC,RAC,TXPWR,DRX,MM,RRC,CID,IMSI,NETNAME,SD,ABND"
:local TErfsts2 "PLMN,EARFCN,RSRP,RSSI,RSRQ,TAC,RAC,DRX,MM,RRC,CID,IMSI,NETNAME,SD,ABND"
:local TErfsts3 "PLMN,EARFCN,RSRP,RSSI,RSRQ,TAC,RAC,DRX,MM,RRC,CID,IMSI,SD,ABND"
:local TErfmmstate {0= "NULL";3="LOCATION_UPDATE_INITIATED";5="WAIT_FOR_OUTGOING_MM_CONNECTION";6="CONNECTION_ACTIVE";7="IMSI_DETACH_INITIATED";8="PROCESS_CM_SERVICE_PROMPT";9="WAIT_FOR_NETWORK_COMMAND";10="LOCATION_UPDATE_REJECTED";13="WAIT_FOR_RR_CONNECTION_LU";14="WAIT_FOR_RR_CONNECTION_MM";15="WAIT_FOR_RR_CONNECTION_IMSI_DETACH";17="REESTABLISHMENT_INITIATED";18="WAIT_FOR_RR_ACTIVE";19="IDLE";20="WAIT_FOR_ADDITIONAL_OUTGOING_MM_CONNECTION";21="WAIT_FOR_RR_CONNECTION_REESTABLISHMENT";22="WAIT_FOR_REESTABLISH_DECISION";23="LOCATION_UPDATING_PENDING";24="IMSI DETACH PENDING";25="CONNECTION_RELEASE_NOT_ALLOWED"};
:local TErfrrcstate1 {0="IDLE";2="CELL DCH"};
:local TErfrrcstate2 {0="IDLE";2="CELL FACH";3="CELL DCH";4="CELL PCH";5="URA PCH";};
:local TErfsdstate {0="NONE";1="CS_ONLY";2="PS_ONLY";3="CS_PS"};
:local a [$ATVAR "AT#RFSTS"]
:local r [$toarrayFromTelitResponse $a];
:local l [:len $r];
:if ($l=16) do={ :set z [$toarrayApplyTemplate $r $TErfsts1]; };
:if ($l=15) do={ :set z [$toarrayApplyTemplate $r $TErfsts2]; };
:if ($l=14) do={ :set z [$toarrayApplyTemplate $r $TErfsts3]; };
#:if ($l>16 || $l<14) do={ :error "Frfsts got unexpected length ($l) from: $r"};
:set ($z->"MM") ($TErfmmstate->($z->"MM"));
:set ($z->"RRC") ($TErfrrcstate1->($z->"RRC"));
:set ($z->"SD") ($TErfsdstate->($z->"SD"));
#cleanup
:set ($z->"ABND") [:pick ($z->"ABND") 0 [find ($z->"ABND") "\n"]]
:return $z;
But scripts fixing up core functionality of the modem, I’m not sure that’s the best plan. But the $ATVAR above at least solve remove the “OK” part if you wanted to try.
