SMS script
it is possible to make a script that work when the router get SMS?
let say -
if I get sms with the word “on” then enable hotspot\send log info to mail…
it there an example of something like this?
Thanks ,
Take a look at this script I use for sending an SMS to Email.
http://forum.mikrotik.com/t/script-on-rb411u-to-check-credit-on-3g-connection/55847/1
I am sure you can adapt it for your use.
something is not working for me
I can’t read the SMS (but if I put the SIM in the phone I see there is a SMS)
this is the print:
/tool sms print
receive-enabled: yes
port: usb2
channel: 4
secret: 1234
allowed-number:
keep-max-sms: 0
can you tell me what is the “secret”? I put 1234 for no reason , maybe this is the mistake?
thanks ,
The pin for the SIM card (Should be “0000”, unless you’ve changed it)?
its a new SIM - never change it , I will try 0000 (thanks , I didn’t know it)
and does it matter which channel I’m using?
again , no reason I choose 4
is there a way to connect with a script to a web service SMS gateway for sending and gettig sms with out SIM card over internet?
weservice or URL webservice , for sending some critical logs ,
TanQ
the script is still not working
I can send\receive SMS , and I can see them
but when I run the script I see in the log "SMS to Email script started "
and that is all
not getting any mail or “SMS to Email script ended”
help?
thanks,
You cannot choose any number for the Info channel.
It must be the correct one for your GSM Modem.
Try 1,2 or 3??
Once you have the correct info channel, using the “info” button in the PPP connection display window, should show information about the modem manufacturer, network, signal strength and so on.
Thanks ,
now it’s working great!
Thank you!
Deleted because not related.
Dear Dobi thank you for your reply ,
all these operators has a URL for their web service , i just wanted to know has any one set their web service parameters in mikrotik,
i just want to write a script that when one of my ISP internet or BGP goes down , my script connect to that web service by URL and send a sms through it instead of using SIM card and SIM card module ,
TanQ
